Need firmware for this tablet pc rk3028 R70DC (kids tablet)
31
2014/12/30 - 18:01
In this zip there are boot.img, recovery.img and kernel.img. Boot.img and recovery.img does not contain a kernel. So kernel.img is what boots on your tab. Just change this kernel.img in the Roverpad pack and flash incl. eraseIDB.
alene
Forum Posts: 17
32
2014/12/30 - 18:39
nothing again
I use RKDevelopTool_Release_Pack_v1.37 + RK3028ALoader(L)_V2.08, so EraseIDB, and flash it by Oma_RK3026_Roverpad TRC7_JB_4.2.2_v1.0.7z + kernel.img from R70DC_cwm.zip
after flash process ends, I see nothing, just black screen
ok, then I try to boot into recovery mode: I hold vol- and press power, so I see opened Droid pic, and text something like Recovery system 4.2.41
Formatting chache...
Formatting (something else)...
Formatting (another something else)...
Rebooting...
and just black screen again
I try to boot it up in recovery again, but I can't do it 2nd time. now I see lying on it's backside Droid with red alert triangle
from this fact I can think that's recovery crashed while I try to start it first time after flashing. May still problem is wrong offsets when I flash it?
33
2014/12/30 - 19:15
I start thinking your NAND is defective somehow. Flash again with the RK3026 loader.
alene
Forum Posts: 17
34
2014/12/30 - 19:33
same result: eraseidb ok, flashing ok, checking ok
no normal boot, just black screen; when vol- and power, starts recovery with follow text:
Formatting /data...
Formatting /chache...
Formatting (something)...
reboots, and black screen
alene
Forum Posts: 17
35
2014/12/30 - 19:39
oh, my God!
Oma, u're great dude!
after looking at black screen, I pressed power for a few times, and pad starts, shows "Android" logo, as in previous pic I'd attached few post earlier, and (!!!) after that I see Oma logo with electric lights!
so for now I see
USB-Massenspeicher
USB-Verbindung
USB-Speicher aktivieren
I don't understand deutche lang, but I think it's verify about USB-Connection, cause pad still connected to PC
so, I cancel connection selection, and see
Fuhlen Sie sich wie zu Hause...
o, I think, everything works for now!
thank you, dear Oma!!!
alene
Forum Posts: 17
36
2014/12/30 - 20:08
I rejoiced too soon
wifi doesn't works, so I try to reboot pad. and same result - blackscreen, after few times press power - backside lying broken droid
maybe I think problem is in loader? maybe I should to use 3028 loader but not 2.08 version? other version flash program, but not 1.37? how do you think?
alene
Forum Posts: 17
37
2014/12/30 - 20:11
I feel that the solution is somewhere nearby
alene
Forum Posts: 17
38
2015/01/18 - 18:25
hello Oma!
few weeks passed (HappyNewYear congratulations to all ArcTablet crews!)
so I try to turn on this "?№№:;*": pad again ... and it boots fine to desktop, I'm surprized!
but wifi doesn't works, pity.
what I can try to do with wifi? when I press wifi to "ON" it moves to on (blue) and in this moment moves back to "OFF" position...
39
2015/01/18 - 18:29
Ok, which kernel work now? See kernel string in settings/about tab.
victor84
Forum Posts: 23
40
2015/04/03 - 06:59
alene said
hello Oma!
beneve kid's tablet 7 inch also comes with the same processor rk3028a this is the link is the beneve 7 inch aver if it's something
BENEVE-741-3028a-i7-V20131214
says if you served
dack
41
2015/07/14 - 17:28
I am trying to get a nearly identical tablet working.  It looks identical to the pictures in the first post except it has a RK3028 chipset and not a RK3028A.  I've tried using the build here, but I get a "Chip Check Fail" because it's using the RK3028A loader when I need to use the RK3028 loader.  The tablet is also called the Beneve i7 and the information etched on the board is "r70dc_v1.01".
55 Guest(s)
Devices in use: Desktop (52), Phone (3)
jacksonrid
usdown
ibob64
kawi
vetBro
