2014/12/06
Hello, I did a dumb thing and tried to flash a custom rom on my tablet ( http://tableta-ieftina.ro/tableta-pc-exclusiv-tab-704dc-7-dual-core-transport-gratuit/157.htm ) and now I bricked it. Can anyone give me a firmware/rom to install on it via RKTools?
Details:
Operating System |
Android 4.2.2 Jelly Bean |
Display
7” |
Resolution | 800x480 (XGA) 16:9 |
Touchscreen |
Capacitive multitouch 5 points |
Processor | Dual Core ARM Cortex A9, 1 GHz, Rockchip 3026 |
GPU | Dual Core Mali 400MP2, supports OPNEGL ES1.1/2.0 |
RAM Memory |
512Mb DDR3 |
Internal Memory |
4 GB |
External Memory |
Maximum: 32 GB Micro SD Card |
Camera | Front – 0.3 Mp |
Wifi | IEEE 802.11b/g/n |
3G | Supports 3G dongle extern TD-SCDMA/WCDMA/EVDO |
GPS | No |
Light Sensor |
Yes |
Gravity Sensor |
Yes, 3D-GSENSOR |
USB |
1x microUSB , supports OTG, Supports charging |
Audio |
Speakers 1W, 1x 3,5 mm jack |
Microfone |
Yes |
Multitasking | Yes |
Audio | MP2,MP3, WMA, OGG, AAC, FLAC, APE,WAV |
Video |
AVI, WMV, MP4, MKV, RM, RMVB,FLV, MPEG1/2/4 , MJPG , H263 ( 1280 × 720 ) , H264 ( 720 × 480 )
MS Office | Suports Word, Excel, PowerPoint |
Adobe Flash | Adobe Flash Player 11.1 |
Applications |
Android Market, Browser, Google Maps
Photo | JPEG, BMP, GIF, PNG, JPG |
E-book | ANSI, UNICODE TXT, PDF, PDB, HTML, EPUB |
Language |
Englsih / 70 other languages |
Charger |
2200 mAh
Battery Life |
4 Hours |
Colours |
White |
Weight | 300 g |
Dimensions | 191 x 109 x 10 mm |
Accesories | Alimentator priză, cablu USB, cablu OTG, manual de utilizare în limba română |
Check out this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-sumvision-cyclone-odyssey-7-android-4-4-2-kitkat-custom-root-firmware-20140622/
Change kernel http://crewrktablets.arctablet.com/?wpfb_dl=2373 in folder rockdev/Images before flash.
SinTakaiPer aspera ad astra, we rock the Tablets !
2014/12/06
Check out this build: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-sumvision-cyclone-odyssey-7-android-4-4-2-kitkat-custom-root-firmware-20140622/Change kernel http://crewrktablets.arctablet.com/?wpfb_dl=2373 in folder rockdev/Images before flash.
Oma, you are the Android God. Thank you so much for your help <3 I am forever in your debt
Edit#1: Everything works fine except the touchscreen, it seems to be inversed (Ex: I touch right side and device thinks it's left) also, rotation seems to be off (Rotation fixed with Gravity Calibration Unit)
Edit#2: Wi-FI doesn't work, power button doesn't make unlock screen appear after tablet screen goes dark. Anything I can do?
The kernel does not fit. Use an usb-mouse to go on.
Download a terminal emulator from Play Store. Boot tab fresh and try to enable Wifi a few times.
Open the terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
The logs are now on your internal sdcard. Copy to PC, zip them and upload the file here.
Ok, found some hints that the tab is based on PCB ZM726C. So, same PCB as Chuwi V17pro.
And this kernel for 800x480 screen: http://crewrktablets.arctablet.com/?wpfb_dl=1874
2014/12/06
Ok, found some hints that the tab is based on PCB ZM726C. So, same PCB as Chuwi V17pro.And this kernel for 800x480 screen: http://crewrktablets.arctablet.com/?wpfb_dl=1874
Looks the same, except mine has a single camera. Gonna give it a spin and keep you updated. x) Also, I got the hang of the reversed touchscreen so I can operate it without a usb mouse. I'ma have some trouble downloading the terminal emulator from the store since wi-fi doesn't work but I think I can find a alternate apk to download from pc and move to SD
Edit#1: This one isn't good. Screen if off (about 0.5 cm to the left), touchscreen doens't seem to work at all, USB mouse doesn't work either (could be the mouse though, not sure, got nothing else to test it on xD ) Also, sometimes when it opens it gets stuck in bootloop (Titan > Oma, screen gets 'pixelated' > Titan >Oma >Repeat)
Ok, try this V17pro build with the manta kernel. Just to see if you get wifi.
The kernel from post #4.
64 Guest(s)
Devices in use: Desktop (56), Phone (8)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
