need any compatible firmware for this rk3026
Need to find a compatible firmware for tufsen opentab v1.0 rk 3026
yurais
2015/11/30 - 01:02
cant find anything for months now.
This is all the information I have so far
tufsen opentab 10
7 inches
board: ak47_bt_v2.0
CPU rk3026
wifi rtl8723bu
tactil zet6251
nand: SK Hynix H27UCG8t2btr (8GB)
ram:2x elixir 1232 n2cb2g16hp-01 (256MB?)
table is brick, stuck at boot logo.
2015/11/30 - 17:08
Pls check all firmware with the right resolution: http://www.panduoduo.net/s/name/rk3026%2B8723bu
Maybe you have luck.
yurais
2015/11/30 - 23:47
Hi
Is there any way to know the tab resolution? since it is dead...
it is a 7inch tablet but I see it smaller than normal chinese 7 inch tablets
2015/12/01 - 17:38
The box or the invoice or the shop you bought from.
yurais
2015/12/10 - 17:04
sorry, but non of these info is available
I got the tablet as it is now, no boxes or invoices
am a bit confused, I dont know how to select the right resolution and I cant download all the files there
any suggestion which resolution for starting to test with ?
yurais
2015/12/26 - 22:04
I downloaded one of the firmwares. one with resolution 1024x600
it revived the tablet, thats good news, but no touch schreen, and the screen is rotated.
I checked and almost all firmwares in that list are for gsl1680 touch screen, I need one with zet6251 driver.
any help? now we know it is 1024x600 resolution.
yurais
2015/12/29 - 20:54
Hi !
am downloading the file from the password protected link, I will try and postthe result.
I prefer a tablet which has no wifi to one with no touch sacreen, so, if after all of this tests I cant make it work, I will try to find one rom with working touch even though wifi&bluetooth are not working.
I will let you know. Baidu servers are kinda slow for me here in Cuba.
yurais
2016/07/27 - 00:45
still no luck with this tab   🙁
several months safe now...
hotair1983
Forum Posts: 19
Thanks Received: 5
2016/10/25 - 12:52
Search by JINGHUA_1409052_AK47_BT_RK3026_8723BU_GD_V1.2.rar
or check LINK
61 Guest(s)
Devices in use: Desktop (53), Phone (8)
