managed to install cube 30gt rom on my 10.1 tAbLET BUT....
Tags: Rockchip
Related Tags
Thanks Received: 1379
46
2016/07/11 - 17:05
Look at the commands and try again.
any
Forum Posts: 37
47
2016/07/13 - 22:43
any
Forum Posts: 37
48
2016/07/14 - 01:00
1.jpgImage Enlarger
49
2016/07/14 - 16:31
The RK903 wifi module crashes (same as in N101 II rom). Where do you got this info from?
any said
board: tr102_main_pcb_v11 2012_09_18 gou
ic: rk903 tod2002 1310
any
Forum Posts: 37
50
2016/07/14 - 18:20
From the board itself ,I opened the tab to get these Info's
51
2016/07/14 - 18:31
Hm, can you pls upload high resolution pictures from inside?
any
Forum Posts: 37
52
2016/07/14 - 21:50
it is little hard for me but i will try ,by the way i took a full apps back up with titanium app on the original rom would that help us some how ?
any
Forum Posts: 37
53
2016/07/23 - 07:35
1-1.jpgImage Enlarger2.jpgImage Enlarger3.jpgImage Enlarger4.jpgImage Enlarger5.jpgImage Enlarger6.jpgImage Enlarger7.jpgImage Enlarger8.jpgImage Enlarger9.jpgImage Enlarger
hope you can find what you need ,i left the tab opened in case you need any thing else so please tell me if it is ok to close it again it is not easy for me to open it ,i almost cracked the screen before 1 year ago when i tried to open it first time.
54
2016/07/23 - 10:13
Ok, on the third picture you see the RK903 wifi chip.
any
Forum Posts: 37
56
2016/07/24 - 01:14
well do and tell you the results
any
Forum Posts: 37
57
2016/07/24 - 04:57
it gives me this
12.jpgImage Enlarger
58
2016/07/24 - 17:05
Is the card ok? Maybe corrupted by unsafe eject.
any
Forum Posts: 37
59
2016/07/29 - 06:02
this one made wifi button turned on for a few seconds then turned off again
http://crewrktablets.arctablet.com/?wpfb_dl=613
and this one hangs the tab on som two chinese choices
http://crewrktablets.arctablet.com/?wpfb_dl=881
the others ware not working
this image is what happened when i install the package it is the same with all of them
14.jpgImage Enlarger
60
2016/07/29 - 14:37
Ok, pls do a clean install and use only the Pipo S3 wifi fix. If wifi still turns off try it a few times and do a dmesg and a logcat log.
123 Guest(s)
Devices in use: Desktop (115), Phone (7), Tablet (1)
Mr. Groove
andrew51r
vanes_84@
vanes_84
sarnaud
zmeivs
