managed to install cube 30gt rom on my 10.1 tAbLET BUT....
Tags: Rockchip
Related Tags
any
Forum Posts: 37
31
2016/05/25 - 05:52
Pls enable usb debugging in developer settings.
forgot to tell you that this was the first thing i did
any
Forum Posts: 37
32
2016/05/26 - 05:59
Waiting for your reply, how to read my device in cmd
any
Forum Posts: 37
33
2016/07/05 - 06:34
i know it is been a along while but actually i havnt forgot at all ,i hope you still can help me solving the tablet ,i uploaded the file you wanted after uninstalling the driver and installing it again i found the tablet listed in adb devices ,i tried to flash the rom in post 8 without  the loader but only the recovery showed up with no problem but the normal rom woudnt run, this is the demseg for the n101 rom i downloaded before ,if you wanted the dmesg for the rom you linked in posted 18 i will flash it again and upload the dmesg for it.
Thanks Received: 1382
34
2016/07/06 - 19:41
Hm, I am not sure what it was here ...
Wifi according log is RK903, but it seems crashing:
01-02 08:00:03.340 275 339 D WifiHW : Read wifi chip type OK ! wifi_chip_type = RK903
01-02 08:00:03.340 275 339 D WifiHW : wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko
<4>[ 1116.535044] =========== WLAN placed in POWER OFF ========
any
Forum Posts: 37
35
2016/07/07 - 02:32
big thanks for your reply ,you mean it is hard to figure what cause that. would another rom solve this issue
any
Forum Posts: 37
37
2016/07/09 - 04:09
i flashed the build but still the wifi and Bluetooth wont open ,here is the log file i hope it will help:
38
2016/07/09 - 08:26
Pls try the dmesg again. I need a log from 0.0000000 sec. Just reboot the tab before doing.
any
Forum Posts: 37
39
2016/07/09 - 09:07
here it is
40
2016/07/09 - 10:51
Open a terminal and let me have the result of:
lsmod
any
Forum Posts: 37
41
2016/07/10 - 04:08
lsmod
when i tried to screen shot the tab it self i found out that the 16g nand memory storage is not showed only system 100mb but ext memory was found ,so i took the screen shot with other phone and uploaded
tImage Enlarger
42
2016/07/10 - 19:34
Hm, wifi module is not loaded. Try manually:
su
insmod system/lib/modules/rkwifi.ko
lsmod
any
Forum Posts: 37
43
2016/07/10 - 23:18
su
lsmod
It gives me this
Imeg second part
44
2016/07/11 - 15:26
I cannot open that. Just attach the picture to your post.
any
Forum Posts: 37
45
2016/07/11 - 16:32
IMG_20160710_230701.jpgImage EnlargerIMG_20160710_230847.jpgImage Enlarger
Currently Online: Efrairo
101 Guest(s)
Devices in use: Desktop (90), Phone (12)
brau10g21234
brau10g2
ccie2006
silver.surfer
aaandriy
anddna
