2015/12/29
hello
these are board details for my tablet
ticket: 9011-24t120-50401011
chip: rk3066 angc 162 1309
board: tr102_main_pcb_v11 2012_09_18 gou
ic: rk903 tod2002 1310
touch flate: tr101_lcd_fb8 2012_07_05 gou
ic 2: toshipa ll0352 taiwan 1250 9ae th58teg7dcjta20
normal specs
b-smart bs101 10.1" 1280*800
cbu 1.6 dual core
ram 1g
internal memory 1g nand flash 16g
i tried to find it's rom but couldn't find it then i managed to flash cube 30 gt rom on it and the tablet opened the home screen rom but toush was not working however if i connected mouse to the tablet with otg it worked but i found that wireless is not working so as the Bluetooth beside i tried to transfer apps by ext memory card and install it but it gives me error message i checked the install from unknown sourses but no luck.
i will try what ever it takes to solve my 7 month tab problem i don't know which is better ,trying to solve problems on this working rom or installing another one . this the first time i put board specs for my tablet i hope this make different .
this how my original rom look like before changing my rom because of the virus that hit it
Well, every tab has it's specific kernel (hardware abstraction layer). When the genuine kernel is gone nearly no chance.
Maybe this will help: http://www.arctablet.com/blog/forum/rk3066/bsmart-bs101-tablet/?lang=fr
The Yuandao N101 II kernel seems to have the right touch controller driver. Wifi driver could be changed in the build.
Let me first see the wifi chip from the running Cube build.
Open a terminal and type:
cat /sys/class/rkwifi/chip
Post the result.
anyPer aspera ad astra, we rock the Tablets !
2015/12/29
Maybe this will help: http://www.arctablet.com/blog/forum/rk3066/bsmart-bs101-tablet/?lang=frThe Yuandao N101 II kernel seems to have the right touch controller driver. Wifi driver could be changed in the build.
Post the result.
can't thank you enough you gave me hope ,i flashed n101 rom and the touch now is working ,the wifi didn;t work as you said.
because i'am not a developer or an expert i need to confirm with you that i did the right way to know the wifi chib name:
i ran cmd in my win 7 after attaching my device and wrote adb devices but nothing appears on devices list then i tried to copy and past the command you wrote but it says  C:\Windows\System32>cat /sys/class/rkwifi/chip 'cat' is not recognized as an internal or external command,operable program or batch file.
in recovery mode my device does appear but the command says path not found
i realy  appreciate your help.thank you  Â
I did not post a link to that rom because I need this information from the running Cube build first. Download a terminal emulator from Play-Store and let me have the full information.
2015/12/29
I did not post a link to that rom because I need this information from the running Cube build first. Download a terminal emulator from Play-Store and let me have the full information.- Oma -
ok i did what you said and this what appears to me :-u0_a65@android
thanks for your help, waiting for you replyÂ
Is this from what you can read on the chips? Then it is RK903 wifi.
Build: http://crewrktablets.arctablet.com/?p=5617
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1203
Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2682
Just change the kernel in folder rockdev/Image before flash. In CWM install the temp model fix.
2015/12/29
any said
ic: rk903 tod2002 1310Is this from what you can read on the chips? Then it is RK903 wifi.
sorry my job gives me a very little privet time ,i replaced the kernel with n101 rom i dowmloded and flashed it then i flashed the (RK30GENERIC_CWM_.zip) and tried to install the fix zip file you posted but it gives me installation aborted (bad),the recovery version is 6.0.3.1  .by the way i got lost in the Build link you posted so i figured that you meant the n101 rom i already flashed, please be more detailed, like i said i am not an expert i only know what i needed to know to solve my problem:).
Just use build v1.1, change the N101 II kernel and flash incl. eraseIDB. Tab will boot into CWM. Do a factory reset and install the model fix from external sdcard (copy to it before you start). That's all.
2015/12/29
will do and let you know -thanx
2015/12/29
any said
i erased idb without problem but when the flash start it says falid to run boot loader boot time out and when i try to erase idb again it says failed to erase idb , problem is tablet refuses to boot up even to recovery mode and it won't flash with same way i did before with n101 rom with RKBatchTool it says boot faild but it still boot to boot loadder
Could be a driver issue. Which Windows?
Ok, hopefully the NAND is not defective. Flash again incl. eraseIDB. Use key-combination to start tab into flash-modus.
58 Guest(s)
Devices in use: Desktop (46), Phone (11), Tablet (1)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
