2015/02/26
I'm looking for a way to fix my Klipad tablet.
I found here a custom rom for Sumvision Cyclone Odyssey and I thought it would work but no luck, the tablet ended up in a boot loop. Thanks to other topics I tried several other kernels but none of them work. The closest I got to was the "RK3026_sekernel_3036_86v_800x480_incar", the tablet boots fine but the touchscreen doesn't work.
I don't understand because it's written "Klipad Cyclone Odyssey" on the tablet so I thought it was the same model :/
Anyway, I tried to find a stock firmware but Klipad doesn't provide firmwares online...
Thank you very very much for your help, I kinda broke my stepfather's tablet ^^"
Did you check the Cyclone stock firmware? http://sumvision.com/product/cyclone-odyssey/odyssey.html#support
What do you mean with bootloop? Do you see the kernel logo?
Ok, then it is not the right kernel for your hardware.
Tell them what your serial-number is and keep pressure on them to provide the right firmware.
Currently Online: floki
86 Guest(s)
Devices in use: Desktop (79), Phone (8)
floki
orocamora
Ellocojoe
Tonysc17
olegator
Ur
