IRulu X10 rk3028a
After some attempts to flash a new version of android without making a backup, the device no longer boots
2015/03/08 - 18:33
left_gangster
backyardbugbucket
2015/04/05 - 16:07
If you're still around I can attempt to backup my firmware for the rulu x10. The serial number is x1047USJYJ1409031. I searched the irulu download section and found nothing though.
The following users say thank you to backyardbugbucket for this useful post:
left_gangster
left_gangster
Forum Posts: 13
2015/04/05 - 23:31
Yes if you can do it that will be great!!!
backyardbugbucket
2015/04/06 - 00:38
I tried omas root and dump method and nothing happened. Im not smart enough to figure it out. However, I found the irulu download has a "x1046usjyj" file. Maybe that will work for you.
left_gangster
left_gangster
Forum Posts: 13
2015/04/06 - 11:39
Yes I found the "x1046usjyj" file too but I don't know how to flash it to the device and I believe this file is meant to be flashed through cwm. Now the easiest way to backup the firmware using AndroidTool v2.1 is:
1. Open AndroidTool v2.1
2. Go to Advanced Function tab
3. On the Start field put 0 and on Count a very large number like 9999999
4. Press ExportImage and the program will create an Output folder where the firmware file will be located.
If you need more help let me know.
backyardbugbucket
2015/04/06 - 20:08
I'm probably wrong but don't you put that file on an SD card and boot the tablet into recovery mode and update from the SD card?
So it turns out my tablet doesn't have a rockchip. My tablet has an arm cortex a-7 mt8127. That doesn't help you huh?
left_gangster
Forum Posts: 13
2015/04/07 - 01:00
Unfortunately no but still thanks for at least trying to help me, I really appreciate that!
109 Guest(s)
Devices in use: Desktop (104), Phone (4), Tablet (1)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
