Ok, the Deco dump linked above is for kernel #249 and NMC1000 wifi. You tab runs kernel #61 and it has ESP8089 wifi.
Use the system.img from here: https://mega.nz/#!7AMVFQjJ!MggcOXV3csE40t23JpHp31GAubQ2Bu6yQgQ90J_6Xa4
FabyoPer aspera ad astra, we rock the Tablets !
Not yet. But you have 2 GB internal storage now and the external sdcard is mounted as internal sdcard (swapped mounts), which gives plenty of space for game (obb) data.
Flash the TWRP (see instructions.txt) and install the Root Script. That should be enough for the moment.
Here is a full build for ESP8089 wifi: http://crewrktablets.arctablet.com/?wpfb_dl=2714
2015/10/09
Is there any kernel with better image than this one?
I only get 360p max. on youtube videos, or this is not controled
by the kernel?
Another question about the kernel. does it not control the wifi also?
Why i couldn´t turn the wifi on if i had the #61 kernel too, before i flash this last package?
2015/10/09
Here is a full build for ESP8089 wifi: http://crewrktablets.arctablet.com/?wpfb_dl=2714- Oma -
Hi
The Twrp recovery isn´t working with this build.
Need to change something?
2015/10/28
Hi, I have one tablet that I think it has the RK3126 chip. It came with Android L 5.0.2. Is there any way to install Kitkat on it?
Here is the pics that I took from it (cpu-z)
https://drive.google.com/file/d/0B1UFkhe4TVpKMmZRekxZakZpSTA/view?usp=sharing
https://drive.google.com/file/d/0B1UFkhe4TVpKLXhBTmwyeUlrdFU/view?usp=sharing
2015/10/28
Fabyo said
danilosanchez said
@Oma7144 do you know something about it?Why do you want KitKat instead of Lollipop?
I want lollipop instead of KitKat. Lol
Because I have two tablets with almost the same specs and the one with Kitkat runs a lot better than the one with Lollipop.
5.0.2 is the worst Android version. I would like to install 4.4.4 or 5.1.1 on it.
Hello Fabyo,
Obviously Oma is not around at the moment, he's probably busy with other things/taking a break/away from the Internet.
Be patient !
126 Guest(s)
Devices in use: Desktop (91), Phone (35)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
