Help flash tablet with Rk3126 chip
Can´t flash bootloader
Fabyo
Portugal
Forum Posts: 27
2015/10/16 - 21:45
I´m start to thinking it´s a hardware related problem.
Can you compile a update.img file with all that images files?
Just to try, to see if this Tab comes back to life.
Thanks Received: 1378
2015/10/16 - 22:39
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2709
Use your system.img and uboot, kernel, resource from here: http://crewrktablets.arctablet.com/?wpfb_dl=2711
Fabyo
Fabyo
Portugal
Forum Posts: 27
2015/10/16 - 22:55
Can i flash with both usb cables connected?
Usb port and charger port?
2015/10/16 - 22:58
This is mandatory.
    c) connect your tab with the power supply and with the PC via USB cable
Fabyo
Portugal
Forum Posts: 27
2015/10/16 - 23:08
OMG it worked..
Thank you so much Mr. Oma
Fabyo
Portugal
Forum Posts: 27
2015/10/16 - 23:15
Oh wireless is not working...
What i should do?
2015/10/16 - 23:23
So the question is what hardware revison is it? We know one with ESP8089 wifi and one with NMC1000 wifi. Boot the tab fresh, try to enable wifi and let me have a dmesg log: http://forum.xda-developers.com/showthread.php?t=1944776
Fabyo
Portugal
Forum Posts: 27
2015/10/16 - 23:31
I really dont know what revision is, but i know the kernel is 3.10.0 #249
This one i flashed is #61. that must be the problem
I tried flash #249 but the screen stucks at boot logo. :/
How can i properly flash the #249 kernel?
2015/10/16 - 23:33
Ok, kernel #249 is NMC1000 wifi. You need to change 3 images: http://crewrktablets.arctablet.com/?wpfb_dl=2710
Fabyo
Portugal
Forum Posts: 27
2015/10/16 - 23:57
I have to put those three images in folder, or
the three ones with the original dump? I put those three you provided
and get a blank screen...? What´s the procedure?
I´m sorry im a litle noob in this.
2015/10/17 - 10:32
Same procedure as in post #17. However, blank screen could indicate a wrong kernel. Are you sure it has had kernel #249?
Fabyo
Portugal
Forum Posts: 27
2015/10/17 - 10:57
Hi
Well i´m really not sure it´s #249, but everyone says this new version quadcore is.
When i flash the resource file with 254kb it Works image ok, but when i flash the one with
16338kb from #249 kernel it gives no image at all. maybe this file is wrong? i dont know
or the adress is wrong?
Can you do a new flash pack to test with the #249 kernel?
Fabyo
Portugal
Forum Posts: 27
2015/10/17 - 11:53
Here is a dmesg
https://mega.nz/#fm/TsM2iYaA
2015/10/17 - 13:01
Not a valid link. Simply attach the log to your post.
Fabyo
Portugal
Forum Posts: 27
2015/10/17 - 13:11
I can´t attach files..
see this link please...
https://mega.nz/#!TpEQQIZD
key: IoBVeL4-juvkcRdkotRT5gPp2SRbcy9k_XSqNc6EF6k
105 Guest(s)
2 Guest(s)
Devices in use: Desktop (96), Phone (9)
KuPuK
aminpk
GUCHEZ MICHEL
errorsdoc
patricktron
jackmiller5623
