Flashing Rockchip update.img firmware on Linux (RK_BatchTool v1.7 equivalent)
2014/04/10 - 15:26
So far, flashing an update.img style firmware was only possible under Windows OS using
Rockchip_Batch_Tool_v1.7 (RKBatchTool.exe) application.
Thanks to the great guys at radxa.com there is now an alternative on Linux.
See there page here: http://radxa.com/download/
Description Linux Windows Note
Firmware upgrade tool – Format and install firmware to NAND flash Linux_Upgrade_Tool_v1.16.zip(1.2M) RK_BatchTool_V1.7.zip(567K) Readme
Partition upgrade tool – Install images to NAND flash by partitions rkflashkit_0.1.1_all.deb(143K) RKDevelopTool_v1.37.zip(534K) Readme
As a backup, we are posting mirror for the files:
The procedure is documented on Radxa WIKI.
Linux
Rockchip has provided tools for upgrading within Linux (closed source) since Android 4.4. It's called upgrade_tool. It supports update.img, parameter, bootloader and other partitions, and it's command line based.
rkflashkit is an open source GUI version flashing tool for rockchip devices. It can not flash bootloader or parameter, only supports kernel and other partitions, but it supports backup the partitions.
For developers: The initial RE work of the Rockchip bootloader updating protocol is by naobsd and has been improved by some in rkflashtool. linuxerwang has made a GUI version of the rkflashtool called rkflashkit. Please note: both rkflashtool and rkflashkit can not flash the rock/update.img and can only flash within rock/bootloader mode and not rock/mask rommode because the rock/mask rom updating protocol is not RE yet. If you are interested in the RE protocol ping naobsd at #radxa on IRC. Since the rock/bootloader has remained unchanged for a long time it's enough for normal usage. If you don't know what this means, just ignore it.
Upgrade_tool from Rockchip
Download the Rockchip linux upgrade tool here. Unzip it and you will get a file called upgrade_tool which is a binary executable file under Linux.
Flash update.img
Let the board go to rock/recovery mode and run the following command to flash the rock/update.img:
sudo ./upgrade_tool uf /path/to/update.img #(UF Upgrade Flash)
If you have an error with upgrading you can low level format the nand flash first with the following command:
sudo ./upgrade_tool lf #(LF Lowlevel Format) This will erase everything on nand
Flash parameter
sudo ./upgrade_tool di -p /path/to/parameter #(DI Download Image)
Flash bootloader
sudo ./upgrade_tool ul /path/to/bootloader #(UL Upgrade Loader)
Flash the kernel(boot.img)
sudo ./upgrade_tool di -b /path/to/boot.img #(DI Download Image)
Others
There are other commands in the upgrade_tool, such as:
UL: upgrade the loader
EF: erease the nand flash
Please post your feedback on how this procedure works for you.
Piperos
Forum Posts: 13
2014/04/13 - 23:08
Thank you very, very much for this topic :)
I look forward to test it, is there anything not fixable if I mess things up?
137 Guest(s)
Devices in use: Desktop (133), Phone (4)
