E-Ceros Vision S - potential brick?
julz
2014/09/29 - 16:32
Hi there,
my name is Julian and I'm new to the forum. I've seen a lot of helpful posts around here, but i couldn't find an answer to my problem.
I hope you can help me with that:
I just got an E-Ceros Vision S (CVYF-104130) and tried to install a new firmware. I used the RK Batch Tool. At first it looked like i've been successful. But then i had to realize that my tablet is bricked. I tried to install the Vido M10 firmware provided here in the forums.
It worked fine with my E-Ceros Vision i bought 2 months ago, but with the new version it doesn't.
Since i tried to flash it via RK BatchTool, it only boots on to a black screen, and keeps on rebooting a few times until it shuts down. You can hear the Windows "USB-Device plugged in / out" sound everytime it reboots and it gets recognized by the Batch Tool. But thats it. I can't even get into the recovery mode with +/- Vol. + Power Buttons.
Well, since i don't have the original firmware (yes stupid me not to make a backup), is there an chance to get a running Android Version back on to the tablet?
Also i'm very new to the topic and would be very thankful for your support - i don't want to own a 200$ bookstand :(
Techncial Data (as provided by the manufacturer):
Operating System: Android 4.4
Hardware Chipset: RK 3188 Cortex A9 Quad core
Speed: CPU 1.6GHz
RAM: 2GB
Screen: Multi-touch, support 10 point
Screen Size: 10.1 inches
Display Resolution: 1920Ă—1200
Ports/Slot/External Sensors: Micro SD Card Slot
3.5mm Audio Jack
HDMI
Micro USB
Internal Memory: 16 GB
External Memory: Micro SD Card up to 32GB
Battery Life: 2 Hours
Standby Time: 72hrs
Battery capacity mAh: 7000
Camera Resolution: 2MP Front Facing Camera
5MP Back Facing Camera
Picture format: JPG, BMP, GIF, PNG
Video format: AVI(H.264, DIVX,XVID,RM,RMVB,MKV,WMV,MOV),MP4(H.264, MPEG,DIVX,XVID), MPEG, MPG,FLV,HD 1080P max
Music Formats: MP3, WMA, FLAC, AAC, WAV, OGG, MP2, 3GP, MA4
E-book Formats: PDF, EPUB, FB2, TXT, RTF
WiFi: YES (802.11 b/g/n)
3G: YES (via USB 3G Dongle)
Bluetooth: YES
Languages: Afrikaans, Bahasa Indonesia, Bahasa Melayu, Dansk, German, English, Spanish, French, Italian, Magyar, Dutch, Polish, Portuguese, Vietnamese, Turkish, Greek, Russian, Arabic, Thai, Korean, Chinese (Simp), Chinese (Trad), Japanese
Certification: CE, FCC, RoHS
Dimensions (mm): 310 x 215 x 55 (L x W x H)
Thank you!!
Best regards
Julian
Thanks Received: 3170
2014/09/29 - 16:47
Chinavasion seems to have some firmwares and documents there, unfortunately I couldn't find anything for your device Confused
Maybe you can try to get in touch and request the firmware at their contact page or thru your reseller.
Thanks Received: 1385
2014/09/29 - 16:47
Pls ask the E-Ceros support to provide a link to the firmware.
julz
2014/09/29 - 17:23
Thanks for the fast answers. Chinavasion couldn't help, but i'm still waiting for e-ceros' support to answer.
Hope they got the firmware.
Julian
julz
2014/10/01 - 11:52
The E-Ceros support hasn't answered yet. I know it can take some time, but what if they don't have the firmware or won't give me access to it?
Is there any chance to find a firmware that works on my tablet? How big is the risk to brick it completely, while trying to flash other firmware versions?
I'm kinda nervous about that, because the tablet should have been a present :S
Julian
2014/10/01 - 17:03
No chance without the genuine firmware. We need at least the kernel from that firmware.
Booting the tab with a strange kernel can kill the hardware.
julz
2014/10/03 - 20:08
Still no answer from e-ceros, but i had the (quite too easy?) idea of using a recovery software to read out the internal sd and possibly recover the original firmware. Is this just wishful thinking or might that be a solution.
If i sound like a noob it's because i am :)
2014/10/04 - 07:10
You flashed a strange firmware into the tab. So, everything is gone.
If there are other owner of the tab here pls be so kind to let me know. We can dump the firmware. Many thanks in anticipation!
danyrolux
2014/10/14 - 16:40
Cool. Thank you a whole lot for sharing!
2014/10/14 - 17:13
Stock firmware for E-ceros Vision S (CVYF-104130-White) re-uploaded for faster access:
Kernel: Linux version 3.0.36+ (user1@server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #23 SMP PREEMPT Thu Sep 4 11:03:33 CST 2014
Android system: CT1002-eng 4.4.4 KTU84Q eng.user1.20140904.124835 test-keys
Loader: RK3188Loader(L)_V2.15.bin
Download: E-Ceros_Vision_S_cvyf_104130_white_4.4.4_fw.zip
julz
2014/10/15 - 02:28
Yeah! It finally works again! Thank you very very much for the firmware and the support! :)
E-Ceros hasn't provided me a link to the firmware yet - they gave my enquiry to their "engineer" - that's the last I've heard of 'em.
Thanks again, guys!
Donation is on it's way ;)
julz
83 Guest(s)
Devices in use: Desktop (71), Phone (11), Tablet (1)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
