2015/09/24
Does anybody in here have the original firmware for the Dutch DServe DSRV 9708C.
I have managed to flash it using firmware from the Russian Starway S910 (almost identical : Motherboard T-Chip TR975V10)
Flash:(TR975_RK610_RK903_AT38_OV2659>2005_(M_RU@121126)_V411.01_
The device works OK, but I guess the Starway guys did not put in the same cameras as in the "Original" Dutch DServe version, because the Camera App Crashes. This happens on both my DServe devices, so I guess the Starway image contains a wrong driver?
Therefore I would really like to try the original firmware - or if someone has tested another firmware to be 100% compatible with the DSRV 9708C.
Thanks for reading.
zEnterHacker
Firmware of Yuandao N90 II should also work.
Both kernel are in the archive:
http://crewrktablets.arctablet.com/?wpfb_dl=1738
http://crewrktablets.arctablet.com/?wpfb_dl=1280
You can use this build: http://crewrktablets.arctablet.com/?p=1913
Just change kernel in folder rockdev/Image before flash.
2015/12/08
zEnterHacker said
Hi,Does anybody in here have the original firmware for the Dutch DServe DSRV 9708C.
Thanks for reading.
zEnterHacker
At the end did you manage to find better and newer ROM for DServe DSRV 9708C. If you did can you please explain in details so I would try to update my wife's Tablet.
Thanks,
Heechee
Currently Online: helloyuen
66 Guest(s)
Devices in use: Desktop (60), Phone (7)
jumbo65
kalkpits
m12k
StatusQ
helloyuen
melcis
