Could be everything. Every tab has it's specific kernel (hardware abstraction layer). For these cheap tabs they scramble hardware components every batch new. So if the genuine kernel is gone you are not in a good position.
Maybe this build works for you: http://www.arctablet.com/blog/forum/crewrktablets-rk3026-entwicklung-und-customroms-development-and-croms/rom-advan-t2e-android-4-4-2-kitkat-custom-root-firmware-20150130/
Try to identify your board and it's hardware components and check Chinese server.
2015/02/19
Cannot download nothing from this sites.It says server error
Will be gratefull if someone download some and put it here:
2015/02/12
lifesaver said
Cannot download nothing from this sites.It says server error![]()
Try this one, it's from the link you provided and working
rk3026_4.2_c86v08_8089_huike ?? _1024x600_Frozen_gc0309_gc2035_20140815.zip
The download button (marked red):
Also you could try to flash the same rom twice, i've had issues before with a good rom turning black (maybe a very low quality usb cable :p).
2015/02/19
Hi ptolemaeus ,
As i sayd , i cannot download from this site. It's says server or network error. Thank you for your effort.
I want someone to download some firm's from provided link and put it here.
2015/02/19
victor84 said
try this aber such roms if you will rk3026
Nothing happened. Still blackscreen...
121 Guest(s)
Devices in use: Desktop (86), Phone (35)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
