Lost password?
The forums are currently locked and only available for read only access
Arnova 10 G2 - problem
Flashing problem
This topic is locked
gora333
2014/06/03 - 17:15
Arnova 10 G2 has problem with booting - falshing logo all the time. So I decided to give him firmware from arctablet site. I downloaded RKBatchTool 1,7, installed device in windows7, so it could be reconized as Rockusb Device in Device Manager. I loaded  update.img to the rk batch tool, and pressed Restore. Everything was ok, but when it comes to Download Firmware Start it staying at 0% (only once it reached and then stopped at 13%). After some time it throw an error.1.pngImage Enlarger
2.pngImage Enlarger
I have trying everything, RK Andorid tool to erase IDB, R BAtch tool versions 1,6 and 1,7, different firmware, older and newer - always the same problem. Still i can't boot it .
gora333
2014/06/12 - 12:09
Please help...
Thanks Received: 3177
2014/06/12 - 12:38
Maybe try again with a different USB cable, preferably a good quality one.
gora333
2014/06/12 - 12:45
I tried 3 different USB cables (form Nokia, Samsung and one short - 50 cm lenght, 3 different computers, still the same... :/ Once I've got 13%, but then it showed this error.
2014/06/12 - 13:39
Then, maybe it comes from an issue on the flash memory with some memory cells wearing out.
If the device is still under warranty, could be worth sending it for repair/exchange.
gora333
2014/06/12 - 13:40
after warranty...
54 Guest(s)
Devices in use: Desktop (47), Phone (7)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
