Possibly some issues with the NAND. Flash again, incl. Lower Format.
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2673
You can load the CWM by clicking on the empty box at the end of the line.
Sure, that's the stock recovery. It will format the NAND.
It's in the download pack.
2015/09/10
I must have been blind!
Indeed, everything smoothly packed there. After installing the revocery_cwm I was also able to install your additional zip.
Now the sceen is 90° turned wrong instead of 180° 😉
And how do I exit apps? There are not software buttons on the bottom of the screen?
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=2673
What do you mean by no software buttons? There should be the task bar at the button.
2015/09/10
Somehow the tab and me wont get best friends. Now it does not start any longer for half a day. Alsways hanging in boot screen. Only hardware reset on the back turns it off.
Then it turned off after several hours and on the next reboot it boots properly again. Its wired.
Yes, there is NO menu bar like you showed one in your screenshot. The bottom line is empty. This is also what I meant with "software buttons".
Sound like a defective NAND. Typical quality issue of these cheap tabs.
No simple way to verify that. Use the flash pack and change the dumped boot.img, recovery.img and system.img.
Attached pls find the parameter file for the 70c. Change in folder rockdev. Change also all dumped images (boot, kernel, recovery, system) in folder rockdev/Image. Flash incl. LowerFormat.
2015/09/10
Change with what? I used my own backup images that I created and shared with you via Dropbox. But they didnt work.
The recovery was still a CWM and the bootlogo showed your own one.
I'd like to revert to a state that I can sefely send back the device.
Thanks much
The dumped images are ok. Just use the parameter from post #28. When the stock recovery is gone leave everything out in CWM.
81 Guest(s)
Devices in use: Desktop (63), Phone (18)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
