2015/09/05
hi all i have tried to install a custom rom and recovery for my tablet oason m30q and I still Doder installed, or there will be a method to release the two gb RAM which brings since it only uses least one note can not install the recovery so I found online omar I can not do, Greetings
There are 4 different hardware revisions of the tab: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-aoson-m33q-android-4-4-2-kitkat-custom-root-firmware-20140630/page-5/#p49683
Hard to understand what you'd like to ask.
To install a rom we use a Flashtool. Follow the link to the Omni build and download the flash pack. Instructions are included.
Under confirmed installations you will find the Love Li Shun kernel and two fixes.
Just change the kernel in folder rockdev/Image before flash. In CWM install the two fixes.
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1913
Leave the format_NAND fix out. Just do a factory reset in CWM. Then these two fixes (copy them on external sdcard before you start): http://crewrktablets.arctablet.com/?wpfb_dl=1914, http://crewrktablets.arctablet.com/?wpfb_dl=1369
Currently Online: jessicapeterson
81 Guest(s)
Devices in use: Desktop (67), Phone (15)
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
andre92
