about rockchip 2928-g
firmware don´t know wi-fi module
julio00004
2015/06/13 - 09:12
I´ve got a tablet 7'' . reinstall the firmware but It doesn´t recognize module wi-fi.
How can I enable the module?
I have unpacking the firmware and modified boot.img without changes.
I try to add the line: insmod /System\lib\module/rt5370sta.ko
I have put the line in init.rc and init.rk2928board.rc (both found in boot .img) and I don´t  get favorable results. The ROM include both drivers ( rt5370ap.ko rt5370sta.ko).
2015/06/13 - 09:41
Is this the genuine kernel running? Let me see a dmesg log.
julio00004
2015/06/13 - 20:46
hi, this is not the original ROM the tablet therefore is not the genuine kernel.
Where can see a dmesg log?
Is this the log file?
FILE:event-log-tags
42 answer (to life the universe etc|3)
314 pi
2718 e
2719 configuration_changed (config mask|1|5)
2720 sync (id|3),(event|1|5),(source|1|5),(account|1|5)
2721 cpu (total|1|6),(user|1|6),(system|1|6),(iowait|1|6),(irq|1|6),(softirq|1|6)
2722 battery_level (level|1|6),(voltage|1|1),(temperature|1|1)
2723 battery_status (status|1|5),(health|1|5),(present|1|5),(plugged|1|5),(technology|3)
2724 power_sleep_requested (wakeLocksCleared|1|1)
2725 power_screen_broadcast_send (wakelockCount|1|1)
2726 power_screen_broadcast_done (on|1|5),(broadcastDuration|2|3),(wakelockCount|1|1)
2727 power_screen_broadcast_stop (which|1|5),(wakelockCount|1|1)
2728 power_screen_state (offOrOn|1|5),(becauseOfUser|1|5),(totalTouchDownTime|2|3),(touchCycles|1|1)
2729 power_partial_wake_state (releasedorAcquired|1|5),(tag|3)
2730 battery_discharge (duration|2|3),(minLevel|1|6),(maxLevel|1|6)
2740 location_controller
2741 force_gc (reason|3)
2742 tickle (authority|3)
2744 free_storage_changed (data|2|2)
2745 low_storage (data|2|2)
2746 free_storage_left (data|2|2),(system|2|2),(cache|2|2)
2747 contacts_aggregation (aggregation time|2|3), (count|1|1)
2748 cache_file_deleted (path|3)
2750 notification_enqueue (pkg|3),(id|1|5),(tag|3),(notification|3)
2751 notification_cancel (pkg|3),(id|1|5),(tag|3),(required_flags|1),(forbidden_flags|1)
2752 notification_cancel_all (pkg|3),(required_flags|1),(forbidden_flags|1)
2802 watchdog (Service|3)
2803 watchdog_proc_pss (Process|3),(Pid|1|5),(Pss|1|2)
2804 watchdog_soft_reset (Process|3),(Pid|1|5),(MaxPss|1|2),(Pss|1|2),(Skip|3)
2805 watchdog_hard_reset (Process|3),(Pid|1|5),(MaxPss|1|2),(Pss|1|2)
2806 watchdog_pss_stats (EmptyPss|1|2),(EmptyCount|1|1),(BackgroundPss|1|2),(BackgroundCount|1|1),(ServicePss|1|2),(ServiceCount|1|1),(VisiblePss|1|2),(VisibleCount|1|1),(ForegroundPss|1|2),(ForegroundCount|1|1),(NoPssCount|1|1)
2807 watchdog_proc_stats (DeathsInOne|1|1),(DeathsInTwo|1|1),(DeathsInThree|1|1),(DeathsInFour|1|1),(DeathsInFive|1|1)
2808 watchdog_scheduled_reboot (Now|2|1),(Interval|1|3),(StartTime|1|3),(Window|1|3),(Skip|3)
2809 watchdog_meminfo (MemFree|1|2),(Buffers|1|2),(Cached|1|2),(Active|1|2),(Inactive|1|2),(AnonPages|1|2),(Mapped|1|2),(Slab|1|2),(SReclaimable|1|2),(SUnreclaim|1|2),(PageTables|1|2)
2810 watchdog_vmstat (runtime|2|3),(pgfree|1|1),(pgactivate|1|1),(pgdeactivate|1|1),(pgfault|1|1),(pgmajfault|1|1)
2811 watchdog_requested_reboot (NoWait|1|1),(ScheduleInterval|1|3),(RecheckInterval|1|3),(StartTime|1|3),(Window|1|3),(MinScreenOff|1|3),(MinNextAlarm|1|3)
2820 backup_data_changed (Package|3)
2821 backup_start (Transport|3)
2822 backup_transport_failure (Package|3)
2823 backup_agent_failure (Package|3),(Message|3)
2824 backup_package (Package|3),(Size|1|2)
2825 backup_success (Packages|1|1),(Time|1|3)
2826 backup_reset (Transport|3)
2827 backup_initialize
2830 restore_start (Transport|3),(Source|2|5)
2831 restore_transport_failure
2832 restore_agent_failure (Package|3),(Message|3)
2833 restore_package (Package|3),(Size|1|2)
2834 restore_success (Packages|1|1),(Time|1|3)
3000 boot_progress_start (time|2|3)
3010 boot_progress_system_run (time|2|3)
3020 boot_progress_preload_start (time|2|3)
3030 boot_progress_preload_end (time|2|3)
3040 boot_progress_ams_ready (time|2|3)
3050 boot_progress_enable_screen (time|2|3)
3060 boot_progress_pms_start (time|2|3)
3070 boot_progress_pms_system_scan_start (time|2|3)
3080 boot_progress_pms_data_scan_start (time|2|3)
3090 boot_progress_pms_scan_end (time|2|3)
3100 boot_progress_pms_ready (time|2|3)
4000 calendar_upgrade_receiver (time|2|3)
4100 contacts_upgrade_receiver (time|2|3)
20003 dvm_lock_sample (process|3),(main|1|5),(thread|3),(time|1|3),(file|3),(line|1|5),(ownerfile|3),(ownerline|1|5),(sample_percent|1|6)
30001 am_finish_activity (Token|1|5),(Task ID|1|5),(Component Name|3),(Reason|3)
30002 am_task_to_front (Task|1|5)
30003 am_new_intent (Token|1|5),(Task ID|1|5),(Component Name|3),(Action|3),(MIME Type|3),(URI|3),(Flags|1|5)
30004 am_create_task (Task ID|1|5)
30005 am_create_activity (Token|1|5),(Task ID|1|5),(Component Name|3),(Action|3),(MIME Type|3),(URI|3),(Flags|1|5)
30006 am_restart_activity (Token|1|5),(Task ID|1|5),(Component Name|3)
30007 am_resume_activity (Token|1|5),(Task ID|1|5),(Component Name|3)
30008 am_anr (pid|1|5),(Package Name|3),(Flags|1|5),(reason|3)
30009 activity_launch_time (Token|1|5),(Component Name|3),(time|2|3)
30010 am_proc_bound (PID|1|5),(Process Name|3)
30011 am_proc_died (PID|1|5),(Process Name|3)
30012 am_failed_to_pause (Token|1|5),(Wanting to pause|3),(Currently pausing|3)
30013 am_pause_activity (Token|1|5),(Component Name|3)
30014 am_proc_start (PID|1|5),(UID|1|5),(Process Name|3),(Type|3),(Component|3)
30015 am_proc_bad (UID|1|5),(Process Name|3)
30016 am_proc_good (UID|1|5),(Process Name|3)
30017 am_low_memory (Num Processes|1|1)
30018 am_destroy_activity (Token|1|5),(Task ID|1|5),(Component Name|3),(Reason|3)
30019 am_relaunch_resume_activity (Token|1|5),(Task ID|1|5),(Component Name|3)
30020 am_relaunch_activity (Token|1|5),(Task ID|1|5),(Component Name|3)
30021 am_on_paused_called (Component Name|3)
30022 am_on_resume_called (Component Name|3)
30023 am_kill (PID|1|5),(Process Name|3),(OomAdj|1|5),(Reason|3)
30024 am_broadcast_discard_filter (Broadcast|1|5),(Action|3),(Receiver Number|1|1),(BroadcastFilter|1|5)
30025 am_broadcast_discard_app (Broadcast|1|5),(Action|3),(Receiver Number|1|1),(App|3)
30030 am_create_service (Service Record|1|5),(Name|3),(Intent|3),(PID|1|5)
30031 am_destroy_service (Service Record|1|5),(Name|3),(PID|1|5)
30032 am_process_crashed_too_much (Name|3),(PID|1|5)
30033 am_drop_process (PID|1|5)
30034 am_service_crashed_too_much (Crash Count|1|1),(Component Name|3),(PID|1|5)
30035 am_schedule_service_restart (Component Name|3),(Time|2|3)
30036 am_provider_lost_process (Package Name|3),(UID|1|5),(Name|3)
30037 am_process_start_timeout (PID|1|5),(UID|1|5),(Process Name|3)
30039 am_crash (PID|1|5),(Process Name|3),(Flags|1|5),(Exception|3),(Message|3),(File|3),(Line|1|5)
30040 am_wtf (PID|1|5),(Process Name|3),(Flags|1|5),(Tag|3),(Message|3)
31000 wm_no_surface_memory (Window|3),(PID|1|5),(Operation|3)
32000 imf_force_reconnect_ime (IME|4),(Time Since Connect|2|3),(Showing|1|1)
50000 menu_item_selected (Menu type where 0 is options and 1 is context|1|5),(Menu item title|3)
50001 menu_opened (Menu type where 0 is options and 1 is context|1|5)
50020 connectivity_state_changed (custom|1|5)
50021 wifi_state_changed (wifi_state|3)
50022 wifi_event_handled (wifi_event|1|5)
50023 wifi_supplicant_state_changed (supplicant_state|1|5)
50100 pdp_bad_dns_address (dns_address|3)
50101 pdp_radio_reset_countdown_triggered (out_packet_count|1|1)
50102 pdp_radio_reset (out_packet_count|1|1)
50103 pdp_context_reset (out_packet_count|1|1)
50104 pdp_reregister_network (out_packet_count|1|1)
50105 pdp_setup_fail (cause|1|5), (cid|1|5), (network_type|1|5)
50106 call_drop (cause|1|5), (cid|1|5), (network_type|1|5)
50107 data_network_registration_fail (op_numeric|1|5), (cid|1|5)
50108 data_network_status_on_radio_off (dc_state|3), (enable|1|5)
50109 pdp_network_drop (cid|1|5), (network_type|1|5)
50110 cdma_data_setup_failed (cause|1|5), (cid|1|5), (network_type|1|5)
50111 cdma_data_drop (cid|1|5), (network_type|1|5)
50112 gsm_rat_switched (cid|1|5), (network_from|1|5), (network_to|1|5)
50113 gsm_data_state_change (oldState|3), (newState|3)
50114 gsm_service_state_change (oldState|1|5), (oldGprsState|1|5), (newState|1|5), (newGprsState|1|5)
50115 cdma_data_state_change (oldState|3), (newState|3)
50116 cdma_service_state_change (oldState|1|5), (oldDataState|1|5), (newState|1|5), (newDataState|1|5)
50117 bad_ip_address (ip_address|3)
50118 data_stall_recovery_get_data_call_list (out_packet_count|1|1)
50119 data_stall_recovery_cleanup (out_packet_count|1|1)
50120 data_stall_recovery_reregister (out_packet_count|1|1)
50121 data_stall_recovery_radio_restart (out_packet_count|1|1)
50122 data_stall_recovery_radio_restart_with_prop (out_packet_count|1|1)
51000 socket_stats (send|1|2),(recv|1|2),(ip|1|5),(port|1|5),(close|1|5)
51100 netstats_mobile_sample (dev_rx_bytes|2|2),(dev_tx_bytes|2|2),(dev_rx_pkts|2|1),(dev_tx_pkts|2|1),(xt_rx_bytes|2|2),(xt_tx_bytes|2|2),(xt_rx_pkts|2|1),(xt_tx_pkts|2|1),(uid_rx_bytes|2|2),(uid_tx_bytes|2|2),(uid_rx_pkts|2|1),(uid_tx_pkts|2|1),(trusted_time|2|3)
51101 netstats_wifi_sample (dev_rx_bytes|2|2),(dev_tx_bytes|2|2),(dev_rx_pkts|2|1),(dev_tx_pkts|2|1),(xt_rx_bytes|2|2),(xt_tx_bytes|2|2),(xt_rx_pkts|2|1),(xt_tx_pkts|2|1),(uid_rx_bytes|2|2),(uid_tx_bytes|2|2),(uid_rx_pkts|2|1),(uid_tx_pkts|2|1),(trusted_time|2|3)
52000 db_sample (db|3),(sql|3),(time|1|3),(blocking_package|3),(sample_percent|1|6)
52001 http_stats (useragent|3),(response|2|3),(processing|2|3),(tx|1|2),(rx|1|2)
52002 content_query_sample (uri|3),(projection|3),(selection|3),(sortorder|3),(time|1|3),(blocking_package|3),(sample_percent|1|6)
52003 content_update_sample (uri|3),(operation|3),(selection|3),(time|1|3),(blocking_package|3),(sample_percent|1|6)
52004 binder_sample (descriptor|3),(method_num|1|5),(time|1|3),(blocking_package|3),(sample_percent|1|6)
60000 viewroot_draw (Draw time|1|3)
60001 viewroot_layout (Layout time|1|3)
60002 view_build_drawing_cache (View created drawing cache|1|5)
60003 view_use_drawing_cache (View drawn using bitmap cache|1|5)
60100 sf_app_dequeue_before (buffer|1),(identity|1),(time|2)
60101 sf_app_dequeue_after (buffer|1),(identity|1),(time|2)
60102 sf_app_lock_before (buffer|1),(identity|1),(time|2)
60103 sf_app_lock_after (buffer|1),(identity|1),(time|2)
60104 sf_app_queue (buffer|1),(identity|1),(time|2)
60105 sf_repaint (buffer|1),(time|2)
60106 sf_composition_complete (buffer|1),(time|2)
60107 sf_unlock_clients (buffer|1),(time|2)
60108 sf_swapbuffers (buffer|1),(time|2)
60109 sf_repaint_done (buffer|1),(time|2)
60110 sf_fb_post_before (buffer|1),(time|2)
60111 sf_fb_post_after (buffer|1),(time|2)
60112 sf_fb_dequeue_before (buffer|1),(time|2)
60113 sf_fb_dequeue_after (buffer|1),(time|2)
60114 sf_fb_lock_before (buffer|1),(time|2)
60115 sf_fb_lock_after (buffer|1),(time|2)
65537 netlink_failure (uid|1)
70000 screen_toggled (screen_state|1|5)
70101 browser_zoom_level_change (start level|1|5),(end level|1|5),(time|2|3)
70102 browser_double_tap_duration (duration|1|3),(time|2|3)
70103 browser_bookmark_added (url|3), (where|3)
70104 browser_page_loaded (url|3), (time|2|3)
70105 browser_timeonpage (url|3), (time|2|3)
70150 browser_snap_center
70151 browser_text_size_change (oldSize|1|5), (newSize|1|5)
70200 aggregation (aggregation time|2|3)
70201 aggregation_test (field1|1|2),(field2|1|2),(field3|1|2),(field4|1|2),(field5|1|2)
70301 phone_ui_enter
70302 phone_ui_exit
70303 phone_ui_button_click (text|3)
70304 phone_ui_ringer_query_elapsed
70305 phone_ui_multiple_query
71001 qsb_start (name|3),(version|1),(start_method|3),(latency|1|3),(search_source|3),(enabled_sources|3),(on_create_latency|1|3)
71002 qsb_click (id|2),(suggestions|3),(queried_sources|3),(num_chars|1),(click_type|1)
71003 qsb_search (search_source|3),(method|1),(num_chars|1)
71004 qsb_voice_search (search_source|3)
71005 qsb_exit (suggestions|3),(num_chars|1)
71006 qsb_latency (corpus|3),(latency|1|3),(num_chars|1)
75000 sqlite_mem_alarm_current (current|1|2)
75001 sqlite_mem_alarm_max (max|1|2)
75002 sqlite_mem_alarm_alloc_attempt (attempts|1|4)
75003 sqlite_mem_released (Memory released|1|2)
75004 sqlite_db_corrupt (Database file corrupt|3)
76001 tts_speak_success (engine|3),(caller_uid|1),(caller_pid|1),(length|1),(locale|3),(rate|1),(pitch|1),(engine_latency|2|3),(engine_total|2|3),(audio_latency|2|3)
76002 tts_speak_failure (engine|3),(caller_uid|1),(caller_pid|1),(length|1),(locale|3),(rate|1),(pitch|1)
78001 dispatchCommand_overflow
90000 nfc_first_share
90001 nfc_share (size|1|2),(tnf|1),(type|3),(aar_present|1),(duration|1|3)
90002 nfc_share_fail (size|1|2),(tnf|1),(type|3),(aar_present|1)
90003 nfc_ndef_received (size|1|2),(tnf|1),(type|3),(aar_present|1)
201001 system_update (status|1|5),(download_result|1|5),(bytes|2|2),(url|3)
201002 system_update_user (action|3)
202001 vending_reconstruct (changes|1)
202901 transaction_event (data|3)
203001 sync_details (authority|3),(send|1|2),(recv|1|2),(details|3)
203002 google_http_request (elapsed|2|3),(status|1),(appname|3),(reused|1)
204001 gtalkservice (eventType|1)
204002 gtalk_connection (status|1)
204003 gtalk_conn_close (status|1),(duration|1)
204004 gtalk_heartbeat_reset (interval_and_nt|1),(ip|3)
204005 c2dm (packet_type|1),(persistent_id|3),(stream_id|1),(last_stream_id|1)
205001 setup_server_timeout
205002 setup_required_captcha (action|3)
205003 setup_io_error (status|3)
205004 setup_server_error
205005 setup_retries_exhausted
205006 setup_no_data_network
205007 setup_completed
205008 gls_account_tried (status|1)
205009 gls_account_saved (status|1)
205010 gls_authenticate (status|1),(service|3)
205011 google_mail_switch (direction|1)
is the unique file that I found was
2015/06/13 - 21:36
Well, without the genuine kernel no chance. Sorry.
julio00004
2015/06/14 - 10:05
one question: Could I put other kernel similar?
I can copy and paste another similar tablet that It has the same characteristics (processor,wi-fi).
thanks
2015/06/14 - 10:16
No tab is like the other. Often the same tab has different hardware in following batches.
Does the tab have a name? Or do you have some other characteristics to identify (high res pics from inside)?
julio00004
2015/06/15 - 01:28
the tab characteristics are the next:
processor: Rockchip RK2928-G
ROM: 2GB
RAM: 1GB
Wireless ralink: RT5370N
one camera
PCB: TR739_V10   2012.11.27
screen 7 ''
brand: colortab
model:unknown
I reinstall ROM  sanei-73 tab ( more or less similar components).
the unique problem is wi-fi module, overall is working good
2015/06/15 - 06:23
Where can I find the Sanei rom?
As for dmesg: http://forum.xda-developers.com/showthread.php?t=1944776
julio00004
2015/06/15 - 09:11
link ROM sanei N73: https://www.mediafire.com/?aqtp46tabzpbp (three parts).
ok, I taste the dmesg and I write the results
2015/06/15 - 18:04
Firmware Sanei N73 (TR739_RK2928_GT811_GC0308_5931_20130308)
Build name shows clearly that it is for Mediatek MT5931 wifi. So, it will not work for Ralink wifi.
Why do you think your tab has RT5730 wifi?
julio00004
2015/06/15 - 18:27
because the tab has in side behind the logo Ralink and RT5370 printed,remember that sanei ROM is not original ROM the tab
so, Why has the ROM tab integrated the drivers ?
i have unpacked the ROM and I have seen two drivers for ralink: RT5730sta and RT5730ap, for this reason I thought that was possible enable module wi-fi
2015/06/15 - 18:38
No, not possible this way. The wifi footprint is in over 30 different binaries.
julio00004
julio00004
2015/06/16 - 06:37
then ,I can not do about anything ?
thanks for help me
57 Guest(s)
