Hello Oma,
I think there's a build.prop setting for that, I'll check if I can find it back.
Would it fit your needs ?
Yes, when it will set a permanent trigger.
Result is here:
/data/data/com.android.settings/shared_prefs/com.android.settings_preferences.xml
But it will be overrided (I guess by the apk) on reboot.
The variable I was referring earlier is: sys.hwc.compose_policy
It is set to value 6 in build.prop for most Rockchip devices, I was expecting to "Disable HW overlays" by changing from value 6 to 0.Â
I tried on a live tablet, doing a getprop on that property returns the same value no matter if the setting is checked or not. Making a setprop to 0 does not change anything.
I also tried changing the build.prop in a firmware, flashing it and booting on it, no change either.
I'll have a closer look at the Settings and provider APK and will keep you posted.
Nice stuff: http://forum.xda-developers.com/showthread.php?t=2184207
This looks like a good undocumented Android trick, nice find
79 Guest(s)
Devices in use: Desktop (74), Phone (5)
