i am getting a download failed everytime i flash firmware on rkandroid tool!
its about rkandroidtool!
TheCat2016
2016/06/20 - 11:31
Untitled.jpgImage Enlarger
i have a problem with the rkandroidtool, the problem is that when i try and flash with rkflash tool on windows 10 i am getting "download failed, run failed with it and it is really annoying me what it tried:
tried renaming to the right folder extention e.g: ../Example/misc.img
tried and move to a different folder
tried a different bootloader
i tried to edit the config.ini
and change USB ports
but none of these work! 🙁
someone help me resolve this quickly!!!!!!!!!
on top is a screenshot of my problem
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2016/06/21 - 10:23
The fastest or quickest way is to use Win7 OS PC. Win10 depending on the hardware/BIOS combination will only succeed half of the time . Try disabling signature verification and reinstall RK BatchTool in Win7 compatibility mode.
TheCat2016
2016/06/21 - 12:31
It was originally windows 7 but it had that free upgrade to windows 10 but I'll try it and see how it goes I am trying to install omas lollipop rom
TheCat2016
2016/06/21 - 13:35
I MANAGED TO FIX THIS!
see cracktechs post for details of how to fix download failed on rkandroidtool!
So happy that I have android lollipop on my tablet 🙂
One problem is that I have mobile network icon when my tablet does not have a sim tray do you know how to fix this cracktech.
cracktech
Malaysia
Forum Posts: 432
2016/06/27 - 06:14
Sorry about the late reply, since you are using a customs ROM it was probably extracted from another similar model with SIM card. It is normally build into the kernel for these symbols, I can only tell you how to disable the SIM or Telephone files so that it will not search for SIM and give you notification that "SIM card not found" messages. Please ask "Oma" if he have a fix for this as that is his department. I do not like to comment/modify on other peoples work. However glad that you manage to flash successfully! In Win10 if ever you find something that is meant for legacy Win7/XP programs that is the normal way of making them run is by " disabling signature" and "run in Win7 compatibility mode" most of the time it will succeed but then again it all depends on your PC BIOS and attached hardware. Cheers!
65 Guest(s)
Devices in use: Desktop (57), Phone (8)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
