Dumping firmware on Arnova G2 / Arnova G3 and other Rockchip based tablets
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2012/07/02
12:41
Forum Posts: 3932
Thanks Received: 1265
JMI Pulse 10
Here are some instructions on how to dump a firmware of a Rockchip CPU based tablet.
Required Linux system, preferably an Ubuntu/Debian 64 bits (not running in a virtual machine like Vmware or Virtualbox).
You can use Steve (ttz642t) script to dump a Rockchip based tablet firmware:
It uses rkflashtool from XDA: [[** please register to see this link **]]
We have compiled a package with binaries (64 bits) to make it easier for you, so what you need to do is open a console/terminal in Ubuntu, then download the archive using:
wget [[** please register to see this link **]]
then unpack it with
tar xvfz Rockchip_dump_Linux_01.tgz
change dir:
cd Rockchip_dump_Linux
install libusb:
sudo apt-get install libusb-1.0-0-dev
(you'll need to enter your root password when prompt)
Plug the power connector and the micro usb cable on your tablet and put your device in flash mode using a paper clip in the reset button (see [[** please register to see this  link **]] article to discover the right "key" combination for your tablet model to enter flash mode)
Finally run the dump script:
perl ./an10g2_dump.pl
You should have the dumped files in a subdirectory named after the date/time the script was run in the format like 20120702_1238
We'll need the backup.img file from that dump subdirectory.
Thanks to Steve (ttz642t) for the Rockchip and dump perl scripts
Wink
2012/08/03
09:00
Forum Posts: 3932
JMI Pulse 10
In case you don't have a Linux machine available to run this firmware dump method, you can also use an [[** please register to see this link **]] that runs on any operating system that has ADB (Windows, Linux, Mac).
Thanks exelletor for this fine tutorial Wink
2012/08/05
22:15
Dolby
Forum Posts: 64
Arnova 7d G3 capacitive
Thanx Admin & Excelletor,
For the help you gived me to make an firmware dump.
Regards,
Dolby
2x Archos Arnova 7D G3 tablets for my 2 sons. But i have problems to get microsd working on de arnova 7D G3. Help please!
2012/12/10
10:42
jbernardo
No Archos/Arnova device
Thanks, with this I was able to do a full dump of the Lenco TAB-831.
2013/01/21
18:28
adginald
Arnova 9 G3
Many thanks for this tutorial. It worked like a charm on my Arnova 9 G3. One sidenote: you need to set the .pl file to be executable with
chmod +x an10g2_dump.pl
before you can run it.
Dumb question: can I use the resulting backup.img file in the Rockchip flashing tool to restore my stock firmware? Or is there some sort of magic that needs to be performed on it before it can be used in that tool? "backup.img" seems to be the same size as the various custom firmwares available on this site, but I thought I'd ask before giving it a go.
2013/01/23
13:20
Forum Posts: 3932
JMI Pulse 10
The easiest option is to take apart the different images out of the backup.img file.
Check the tools from here:
You'll need (on top of my head) : rkunpack and afptool.
Once you have all the image parts, just setup RKAndroidTool (available from [[** please register to see this link **]]) and flash your device.
2013/01/23
18:01
adginald
Arnova 9 G3
Thanks for the info, admin.
I'm still a little confused, though. I got the RK2918 tools working and used afptool on the backup.img file. It produced the following files:
------- UNPACK -------
package-file  0x00000800  0x0000021B
RK29xxLoader(L)_V2.14.bin  0x00001000  0x0002512E
parameter  0x00026800  0x00000255
Image/misc.img  0x00027000  0x0000C000
Image/kernel.img  0x00033000  0x006DD030
Image/boot.img  0x00710800  0x007BC000
Image/recovery.img  0x00ECC800  0x00958000
Image/system.img  0x01824800  0x0AF5E000
SELF  0x00000000  0x0C783804
Skip SELF file.
update-script  0x0C782800  0x000003A5
recover-script  0x0C783000  0x0000010A
UnPack OK!
As you can see, system.img is the big file, about 175MB. But it doesn't appear to have the all-important "RKFW" header, that all the custom firmwares ("update.img") seem to have.
Which file should I use? Or what else should I do?
Or, is there some documentation of the RK2918 tools somewhere?
2013/01/23
18:39
Forum Posts: 3932
JMI Pulse 10
Well, you should be able to flash all the firmware image part (system, boot, recovery,…) using RKAndroidTool as I mentioned. Just point the bootloader, parameter file and each image to the files you extracted and you should be fine.
For Rockchip firmware related info, you can learn a lot working with the tools I mentioned and experimenting by yourself. This [[** please register to see this link **]] also has some info.
2013/04/09
13:51
me83
Forum Posts: 13
have followed the guide and got as far as running the script ,have made it excutable but when running iget
/Rockchip_dump_Linux# perl ./an10g2_dump.pl
./rkflashtool: 1: ./rkflashtool: ELF: not found
./rkflashtool: 1: ./rkflashtool: : not found
./rkflashtool: 1: ./rkflashtool: �: not found
./rkflashtool: 2: ./rkflashtool: '
'��: not found
./rkflashtool: 1: ./rkflashtool: Z��@: not found
./rkflashtool: 1: ./rkflashtool: +@: not found
./rkflashtool: 1: ./rkflashtool: @: not found
./rkflashtool: 1: ./rkflashtool: '�: not found
./rkflashtool: 2: ./rkflashtool: CE���qX8��������: not found
                                 �: not found
�: not found: 1: ./rkflashtool:
: not foundol: 1: ./rkflashtool:
: not foundol: 1: ./rkflashtool: H�����H���5z
./rkflashtool: 3: ./rkflashtool: �
: not found                        ��������%2
./rkflashtool: 17: ./rkflashtool: Syntax error: ")" unexpected
Reading parameters…
Size of parameters is 0
'��: not found
                                 �: not found
./rkflashtool: 1: ./rkflashtool: ./rkflashtool: 1: ./rkflashtool: H�����H���: not found
'��: not found
                                 �: not found
./rkflashtool: 1: ./rkflashtool: ./rkflashtool: 1: ./rkflashtool: �: not found: not found
./rkflashtool: 2: ./rkflashtool: ./rkflashtool: 1: ./rkflashtool: Z��@: not found
'��: not found
                                 �: not found
: not found
'��: not found
                                 �: not found
'��: not found
                                 �: not found
: not found./rkflashtool: 1: ./rkflashtool:
ELF: not found
'��: not found
                                 �: not found
: not foundol: 1: ./rkflashtool: ./rkflashtool: 1: ./rkflashtool:
: not found���5z
CRC = 00000000
have tried whilst connected via usb and put in black screen and also tried whilst in recovery and also just in normal usb mode but same not found error(following thetutorial directed to thepart after it says grab a paperclip is missing so maybe im missing something am using ubuntu
2013/04/09
14:08
Please donate to support my work
Forum Posts: 2028
Thanks Received: 160
Archos 101 XS
you need to recompile the tools and use it on its own.
2013/04/09
14:25
me83
Forum Posts: 13
these are the usb ids ??
first is just connected, second is flash mode black screen done by holding vol up then reset then release vol
Bus 001 Device 031: ID 18d1:4e21 Google Inc. Nexus S
Bus 001 Device 032: ID 0ac8:8820 Z-Star Microelectronics Corp.
any help as still showing nothing found??
2013/04/09
14:46
Forum Posts: 2028
Archos 101 XS
as i said earlier, the tools that is provided in the first post is more intended for rk2918 chips, not on the new 3066 and 3188, for these new ones, you need to recompile
As a starting point
Most Users Ever Online: 646
Currently Online: sineda, geocos, thatoneguysomeplace, Drigz, coldasice007, netlars, kaylacheergirl, skletters, erichk, icekid, xandz23, garciburbu, goldhuf, dgaid, shimikis, ajlynn, rheenaparas, rgidds, coffinsoul
144 Guest(s)
2 Guest(s)
admin: 3932
globula_neagra: 2028
Guest Posters: 39
Members: 82646
Forums: 132
Topics: 2981
Newest Members: coffinsoul, mcrqaoFY, sqirywBW, Deborahioz, REiN67rus, murrayjbrett
Moderators: HaroldG (117), globula_neagra (2028), exelletor (344)
Administrators: admin (3932)
