2012/11/13
I Uploaded the boot.img, system.img, misc.img, kernel.img, recovery.img and system .img for the Cube U9GT4 Can Anyone compile them into a flashable zip for CWM, and possible add a advanced restart/power menu and edit the kernel to allow undervolting/overclocking. please let me know me and a many others would like to know.Â
well, again you forgot the link.
it is not easy to develop for a device which you do not have
2012/11/13
First 3 files are rar'd system.IMG rest are boot kernel recovery and misc.img
http://www.mediafire.com/?m11j316663dwlnn
http://www.mediafire.com/?neuh3u1ajaukd91
http://www.mediafire.com/?c1815hruag0c98h
http://www.mediafire.com/?qrxw8cqsm8szoa8
http://www.mediafire.com/?k3ryeodxufoi7jw
http://www.mediafire.com/?tu9a969sz6g6b6a
http://www.mediafire.com/?817kyn3shp6ojc1
Let me know what u cone up with sorry for the links being delayed worked black Friday and was tired. Thanks
do you have allready a cwm recovery ?
can you flash the files via fastboot ?
i need to know the mount points.
so i can properly set the partitions which will be flashed in the updater-script.
share the output from
adb shell
su
cat /proc/mtd
df -h
mount
can you also provide the cwm ?
2012/11/13
u0_a66@android:/ $ adb shell
* daemon not running. starting it now on port 5038 *
* daemon started successfully *
error: device not found
1|u0_a66@android:/ $ su
u0_a66@android:/ # cat /proc/mtd
dev: size erasesize name
mtd0: 00400000 00004000 "misc"
mtd1: 00800000 00004000 "kernel"
mtd2: 01000000 00004000 "boot"
mtd3: 01000000 00004000 "recovery"
mtd4: 20800000 00004000 "backup"
mtd5: 08000000 00004000 "cache"
mtd6: a3200000 00004000 "userdata"
mtd7: 00400000 00004000 "kpanic"
mtd8: 1ec00000 00004000 "system"
mtd9: ec600000 00004000 "user"
u0_a66@android:/ # df -h
Filesystem Size Used Free Blksize
-h: No such file or directory
1|u0_a66@android:/ # mount
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
/dev/block/mtdblock8 /system ext4 ro,relatime,barrier=1,data=ordered,noauto_da_alloc 0 0
/dev/block/mtdblock6 /data ext4 rw,nosuid,nodev,noatime,nodiratime,barrier=1,data=ordered,noauto_da_alloc 0 0
/dev/block/mtdblock5 /cache ext4 rw,nosuid,nodev,noatime,nodiratime,barrier=1,data=ordered,noauto_da_alloc 0 0
/sys/kernel/debug /sys/kernel/debug debugfs rw,relatime 0 0
/dev/block/dm-0 /mnt/asec/com.androguide.pimp.my.rom-1 vfat ro,dirsync,nosuid,nodev,noatime,nodiratime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/179:1 /mnt/external_sd vfat rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/31:9 /mnt/sdcard vfat rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/31:9 /mnt/secure/asec vfat rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
tmpfs /mnt/sdcard/.android_secure tmpfs ro,relatime,size=0k,mode=000 0 0
/dev/block/dm-1 /mnt/asec/com.z4mod.z4root-1 vfat ro,dirsync,nosuid,nodev,noatime,nodiratime,uid=1000,fmask=0222,dmask=0222,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
u0_a66@android:/ #
i finished compiling 2 versions but mediafire dont`t works for the moment.
You can put it on /home/globula/public_html on the dev server
It will be available on http://globula.arctablet.com/
i am uploading right now the files which will be available here in about 30 minutes
What i did
-zip file which should be flashed via cwm
In case you get an error like 6 or 7
On the download page i added also a modified updater-script and one update-binary, if the first attempt of flashing does not work, you should only add the updater-script in the META-INF/com/google/android/ if you still get an arror after this add also the update-binary in the same place.
It is hard to create a flashable zip since i do not have the tablet to test packages.
So, i am just trying to learn how to create flashable zip for the moment.
The other requests
-power menu it should be achivable, there are tutorial on xda on how to add it
-for the kernel oc/vid controll involves having the source files, and compiling a new kernel, i don`t know how to do that, and i also don`t like the way in which the boot and kernel are not in one simple boot.img
IN THIS FLASHING PROCESS THERE ARE RISKS INVOLVED LIKE BRICKING YOUR TABLET, IF YOU DO NOT KNOW HOW TO REVIVE YOU ShOULD NOT TRY THIS.
The link towards the CWM recovery does not work.
There was a permissions problem on the public_html files, it's fixed now.
112 Guest(s)
Devices in use: Desktop (102), Phone (10)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
