2012/12/27
My daughters Cube U9GT V has Cube U9GT5 Rooted firmware from VISTURE V4 HD (2013/01/24) installed. All seemed to be working OK until recently, the only problem it had was a band of pixels on the visture boot screen.
But now the tablet will not power on at all, when connected via USB to a laptop and the power button pressed you get a quick flash of device connected, but this is only for about 1 second.
There is nothing displayed on the tablet screen at all.
Any help would be appreciated.
There is one problem, before I do any flashing, she asked me to backup all her app data.
Also the Esc and Volume buttons are depressed below the surface, so if anyone knows how to open the U9GTV, I will attempt to re-position them.
Have you tried to leave the tablet to charge for couple of hours ?
Have a flashed a firmware with Rockchip Batch tool ?
You can flash the one linked below, which is a compatible firmware that also works on the Cube U9GT5 (RK3066):
Don't forget to use Restore button in the tool to flash properly.
2012/12/27
I would have tried that first admin.
But the problem is my daughter has about 4 months of app data as well as photos.
I remember seeing the boot recovery screen yesterday and I simply selected reboot option, but when it did reboot it froze at visture boot screen, so I held the power button until it powered off.
Since then nothing.
Is there a set of button presses to get to recovery screen again.
2012/12/27
Here is where I am at right now.
Just successfully flashed
can you explain what you exactly did step by step when you flashed the tablet ?
2012/12/27
Here are steps I followed,
1) Run Rockchip Batch Tool v1.5
2) Put power adapter in laptop, Hold Volume + then Power button + connect to PC.
3) Green square visible in connected devices on RKBT v1.5
4) Selected FW kasty-cube_u9gt5-based_visture_v5hd_97r_20130412-411-rooted3
5) Everything completed successfully.
Screen still black ?
try to flash an older firmware, using the restore option
I've uploaded the initial 1.0 firmware for the Cube U9GT5 (RK3066 based version) :
2012/12/27
juanjo1024 said
Hi Phil
could you please explain what did you do to open the tablet ? im looking at mine all around and cannot find any visible points to start working on
thanks a lot
Juanjo
If you have one of the iphone opening kits, use the plectrum or other thin wedge and insert between metal back and plastic screen bezel. Work your way around case and it should start to lift. Once it is apart enough ease open with your fingers. Just be careful with the volume and power buttons when putting back together.
Regards
Phil
2013/05/17
philjg66 said
juanjo1024 said
Hi Phil
thanks a lot
Juanjo
Regards
Phil
thanks a lot Phil, im gonna get one of those kits
Juanjo
66 Guest(s)
Devices in use: Desktop (57), Phone (9)
