We got our hands on a Cube U9GT5 (also named U9GTV) and we'll first publish here a first look at this Android tablet equipped with a Retina like display (2048x1536 pixels resolution) This part of the review will focus on the device specifications and the screen test while we'll take some time to evaluate the device performance before giving you our first imprressions.
Cube U9GT5 specifications
U9GT5 Package
The U9GT5 box contains the usual Cube packaging: the tablet, a micro USB cable (to connect to a computer), an USB OTG / HOST cable (to connect USB peripherals) and a microfiber screen cleaning cloth.
The power supply came with a Cube U9GT2 label, but this is a common model for many Cube tablets, it delivers 12 volts output at 2 A.
There have been a few warnings in our forum about the quality of the Cube power charger, as well as the USB cable. Based on the existing feedback and our experience, we
U9GT5 Connectors and buttons
The Cube U9GT5 connectors are located on the right side of the tablet, you will find, from top to bottom: the micro SD card slot, the USB connector (Host / OTG capable), the power supply connector, a microphone hole and a 3.5mm jack for earphones.
The top of the tablet hosts the -/+…
My U30GT-H has died so I can't compare, but the speaker design look the same, the two speakers are located on the side, they sound OK, but I haven't yet watched a movie on this tablet.
I'll probably post some updates after I have spend more time on this tablet.
71 Guest(s)
Devices in use: Desktop (57), Phone (12), Tablet (2)
Mikewood
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
