Original said
yes, flashed Archos boot and it runs perfect now
Except that something is wrong with internal SD card. I can access it with ES file explorer, but can't write anything to it and all apps says there is no SD card on the device.Â
There is a file in /system/etc/permissions that handles the writing, find out more using google, you can edit it, and after that you should be able to sort the things out.
shapipoy
You have two ways, re-flash the stock firmware.
Delete the su from system/xbin/su and Supersu app from system/app/Supersu.apk
shapipoy
2014/12/21
Dear All,
I have flashed this ROM but the touch screen is not working on my tablet.
I have the TUVVA Elemental ROM. I should have backed up the original firmware but I did not.
Any help please, I just need to have the touch screen working then the tablet will be 100%.
Thank you for all your hard work.
Currently Online: Jordi Martinez
85 Guest(s)
Devices in use: Desktop (75), Phone (11)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
