It won't work on a quad-core tablet such as the V99, it's for dual-core RK3066 based tablets only as mentioned in post #12.
2012/10/20
Wow..!!!Â
I must say.. Installing this new firmware.. It is like having a brand new tablet..!!! Â Now it is actually reponsing to commands.. and not crashing after 5 min of use..Â
However I knew it was a matter of time before this memory leak was solved.. And thank God it was.. Or.. thank the dev. that figured this out
Now we just need to get HD mode to run smooth.. Sure it will soon.. but yes... this new firmware was like getting a brand new device.. once again thank you for all your work on these tablets
All the best..
2013/07/06
After updating this firmware everything was running perfectly except front camera, after installing this firmware it is not possible to make video call with front camera cause it displays a grren screen. I think there is a bug in this firmware needed to be fixed( may be front camera driver corrupted)
After this problem i installed the V5 HD original firmware and now front camera is running perfectly.
Can you fix this issue so i can able to install this fast firmware again. Anyway can everybody who installed this firmware try their front cameras , i am sure both will face a green display.
Waiting fixed version of this firmware
Regards
2013/06/22
hakanalkan74 said
After updating this firmware everything was running perfectly except front camera, after installing this firmware it is not possible to make video call with front camera cause it displays a grren screen. I think there is a bug in this firmware needed to be fixed( may be front camera driver corrupted)After this problem i installed the V5 HD original firmware and now front camera is running perfectly.
Regards
My pad is Cube U9GT5 RK3066,My front & back camera is running perfectly.
2013/07/06
retry firmware upgrading or return to original firmware , the problem i faced with front camera resolved by installing the original V5 HD firmware.
Also with this rooted firmware front camera was running perfectly with other android camera applications except its original camera program and skype , i think problem can be easily solved bey the programmer of this rooted firmware.
Also as seen from the posts i am not the only one facing problem with this firmware , so a fix is needed.
2013/07/06
rongwu said
<< Also with this rooted firmware front camera was running perfectly with other android camera applications except its original camera program and skype >>Â
But my pad was running perfectly, including Cube's original camera program.
Yes perfect for you but i really need a fix for my visture v4hd pad, as soon as this rooted one made from visture firm. than it is possible to make a simple fix for my front camera problemÂ
67 Guest(s)
Devices in use: Desktop (57), Phone (10)
Cellarin
kuzin
Dag58
montolla
portvein
POELE
