Here is a firmware update Just another update for the Cube U9GT5 and compatible tablets (Chuwi V99, Visture V4HD, Yuandao N90 FHD, Hyundai Play X900) based on latest Visture V5 HD firmware dated 2013/04/12.Â
Build information:
Linux Kernel:Â Linux version 3.0.8+ (root@xingyu-desktop) (gcc version 4.4.3 (GCC) ) #213 SMP PREEMPT Tue Jan 8 20:36:37 CST 2013
Android build:Â rk30sdk-eng 4.1.1 V5 HD 20130412.094407 release-keys
- increased space for application (/data partition) to 2 Gb
- fixes for memory leak issue, thanks MaX51v
Check the memory leak issue on Cube original stock firmware and this custom firmware:
Download:Â kasty-cube_u9gt5-based_visture_v5hd_97r_20130412-411-rooted3.zipÂ
This firmware is confirmed to work on the Cube U9GT5, it should also work with compatible tablets: Chuwi V99, Visture V4HD, Yuandao N90 FHD, Hyundai Play X900
Use Rockchip Batch Tool version 1.5 to flash the firmware, use Restore button.
Great thanks to whitetigerdk for his support !
karmantyu, IGNEOUS, secondry2, alvins, whitetigerdk, noyaud, zy9328547, angry23, ri9000 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/01/29
I´ve just tried to flash my U9GT5 and Rockchip Batch Tool returns me an error after hitting Restore button. Any idea?
Thanks!
Stef
Loading firmware...
Loading firmware Finished.
Loading firmware...
**********Restore Action**********
<Layer 1-1-2> This operation didn't do,because of not supporting!
**********Restore Done Success<0> Fail<1> Time<1634828>ms**********
Loading firmware...
Loading firmware...
Loading firmware...
The following users say thank you to stefci for this useful post:
rongwu, puppinooIs your tablet a U9GT5 RK3066 model, not the RK3188 ?
Does this happen when flashing other custom firmwares ?
Was the square (with number 1 in it) green before you hit Restore button ?
It should be Green, not pink. Try to hit the switch button or check the details here, it works about the same on the U9GT5:
http://www.arctablet.com/blog/forum/cube-u30gt2/help-flashing-new-rom/
2013/01/29
It was a problem with RK30 driver installation in Windows8, system didn't accept the driver installation until I followed these steps. Now it is flashed ok
http://chinagadgetsreviews.blogspot.cz/2013/01/how-to-install-rockusb-driver-v20-on.html
Going to check the ROM
Thanks anyway.
Stef
Sorry, it won't, this is for RK3066 based models only.
We should soon have custom firmwares for the U9GT5 RK3188 based model.
85 Guest(s)
Devices in use: Desktop (71), Phone (13), Tablet (1)
Ellocojoe
Tonysc17
olegator
Ur
beelink
TheMentor
