Just another update for the Cube U9GT5 and compatible tablets (Chuwi V99, Visture V4HD, Yuandao N90 FHD, Hyundai Play X900).
This new firmware comes from a stock firmware of a VISTURE V4 HD tablet and is dated 2013/01/24.
Build information:
Linux Kernel:Â Linux version 3.0.8+ (root@xingyu-desktop) (gcc version 4.4.3 (GCC) ) #236 SMP PREEMPT Thu Jan 17 15:19:46 CST 2013
Android build:Â rk30sdk-eng 4.1.1 Visture V4 HD 20130123.094407 release-keys
- root with latest SuperSU 0.99 (free version)
- writable /system partition
- increased space for application (/data partition) to 2 Gb
Download: kasty-cube_u9gt5-based_visture_v4hd_20130124-41-rooted.zip (removed)
For Cube U9GT5, should also work on compatible tablets: Chuwi V99, Visture V4HD, Yuandao N90 FHD, Hyundai Play X900
Use Rockchip Batch Tool version 1.5 to flash the firmware, use Restore button.
I haven't yet tested this firmware on my Cube, please let us know how it works for you.
2013/01/29
just tested on my u9gtv and doesn't load the firmware during "restore"process with Rockchip Batch Tool v1.5. it cuts the process in <Layer 1-1-3> Download Firmware Fail .nothing happens then. any idea? the firmware from thread Cube U9GT5 Rooted firmware from 97R (2013/01/08) works without prob.
Stef
Ok, thanks for testing.
I should be able to have a look on my Cube by tomorrow and correct the problem.
I have removed the download as the firmware doesn't work, I don't recommend flashing it if you have already downloaded the custom firmware.
I have tried the unmodified 2013/01/24Â firmware download from Visture website, it actually doesn't bootÂ
2012/10/20
New ROM is out for the Visture V5 HD (I have experienced that the the Visture V4 HD and the Visture 5 HD are the same devices) .. only difference is the partition layout.. the V4 HD has 1GB data set to system memory.. the V5 has 2GB..
The V5 ROM can easily be installed on the V4..Â
New ROM dated March 15th has been released. I have tried to flash the stock ROM .. Camera app is missing..
Oh and admin.. I forgot.. Promised you to donate a little..Â
Done by now.. So that I won't forget again.. Â Sorry..
Thank you for your whitetigerÂ
It's good to read that the Visture V5 HD works on the V4 HD, as there is still an important hardware difference with 2 GB of system RAM (not flash memory) on the V5 HD vs 1 GB of RAM on the V4.Â
I'm currently downloading the image, should have a custom firmware ready for tonight.
whitetigerdk, quick post to let you know that my build of 03/15 firmware doesn't boot on my test Cube U9GT5, I'm currently checking about the problem, will post here when there's something to test.
siggiscube If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I'm back to work on the Visture V5HD custom firmware, I hope to have a test version ready by tomorrow.
Edit:
Actually, I'm now updating V5HD firmware from latest official
"V5 HD FW Android 4.1 & upgrade 20130418" that refers to:
http://pan.baidu.com/share/link?shareid=442178&uk=571188649
(actual file: V5 HD FW Android 4.1 20130412.rar )
Custom firmware based on the Visture V5 HD (2013/04/12 version) posted:
41 Guest(s)
Devices in use: Desktop (38), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
