[ ROM ] Cube U9GT5 Rooted firmware from Hyundai Play X900 (2013/01/09)
cuu2
2013/01/16 - 19:26
I've solved yet, I had not installed the drivers. I'm silly
Thanks Received: 3170
2013/01/17 - 20:20
I have just posted a firmware for the 97R dated 2013/01/08, it seems a little faster than the Hyundai Play one.
http://www.arctablet.com/blog/forum/cube-u9gt5/cube-u9gt5-rooted-firmware-from-97r-20130108/
Frontier
Forum Posts: 11
2013/01/24 - 08:04
Thank you very much for providing this ROM.
Hyundai has an updated version of their ROM dated 10-Jan-2013, do you plan to update your ROM to reflect these changes?
Thank you very much in advance.
2013/01/24 - 08:58
Frontier said
I may build a custom firmware based on this update, but I'd really prefer that you test it first and see if it's working better than previous versions. Also, compare the version number for the Android system and Kernel in Settings / About tablet with the information I gave in post #1 to make sure this update is a different version.
Finally, it would save me some time if you can provide a direct download link for the update.
Frontier
Frontier
Forum Posts: 11
2013/01/24 - 09:30
After comparing this ROM with the details you mention on the first page, it's the same one.
I've also recovered the file Hyundai put on 9/1/2013 from a backup and compared it with the ROM of 10/1/2013 and it's the same (same files, different creation dates). I don't know why they did this, but it seemed as they have fixed something.
The download page (Google Translate) for the X900 ROMs is here.
Again, thank you for your help and sorry for any inconvenience caused.
2013/01/24 - 09:39
No problem, you are welcome to post when there are updates Wink
Frontier
Forum Posts: 11
2013/01/24 - 09:48
I will watch this thread and notify you of any future updates.
May I suggest something (don't know if it's the right place)?
Can you remove - from a future ROM - apps like Chrome, Facebook and Skype, so that the ROM could be even more "clean"? Chrome especially is bloated, anyone who wants it can always install it from the market :)
2013/01/24 - 09:54
Sure, newest firmwares should have Facebook and Skype removed.
About Chrome, I usually left it as it showing as incompatible app and couldn't be installed from Google Play Store. It should be fine now with the Play Store fixes I am adding in the newer custom firmwares, so I'll probably remove Chrome as you are requesting.
Thanks for your help watching for new firmwares Smile
chouk
2013/01/24 - 23:20
i installed this rom and now my u9gt5 don't start(black screen).put in the charge but no charging.put in usb but no reaction.can you help me ?thanks
Thanks Received: 264
2013/01/24 - 23:43
Did you used the restore option or the upgrade ?
chouk
2013/01/25 - 00:28
how can i do this
Frontier
Forum Posts: 11
2013/01/25 - 09:03
Run the RKBatch tool and connect the tablet via USB cable.
If the tablet is not recognized (i.e you see a message with "no RKusb" e.tc), you have to put it in flash mode: hold down the power and Volume+ buttons together and keep the tablet connected to the PC via USB cable. As I assume you've already installed the rockUSB drivers, the RKBatch tool should detect your tablet (you will see a green port number in the RKBatch window).
Select the ROM you want to flash and hit the UPGRADE button to start the flashing procedure.
2013/01/25 - 10:45
We recommend to use restore, not upgrade, the upgrade has bricked enough tablets on the RK Soc, even in the front page of download, it is writen , restore, not upgrade.
chouk
2013/01/25 - 11:39
ok but the tablet don t run anyway. nothink reaction in dc .
alpappy
2013/01/25 - 18:30
HI  Thanks for the rom  Works great  Alter build prop and full market too Is it possible to change the boot image Eg use original one.  Can teh boot image be loaded over the rom  ie afterwards
thanks
Alan
69 Guest(s)
Devices in use: Desktop (59), Phone (10)
Cellarin
kuzin
Dag58
montolla
portvein
POELE
