Here is another custom firmware for the Cube U9GT5 or compatible tablets (Chuwi V99, Visture V4HD, Yuandao N90 FHD, Hyundai Play X900)
This new firmware comes from a stock firmware of a Hyundai Play X900Â tablet released yesterday (2013/01/09)
Based on the quick tests I did, there is still some lag in HD mode but I found it to be the most responsive compared to all firmware for the U9GT5 and compatible machines I have tried so far. Give the system a little time after you have installed and synced all your apps.
- root with latest SuperSU 0.99 (free version)
- writable /system partition
- removed most Chinese and unnecessary applications (there is still a little cleaning to do)
- increased space for application (/data partition) to 2 Gb
Build information:
Linux Kernel:Â Linux version 3.0.8+ (root@xingyu-desktop) (gcc version 4.4.3 (GCC) ) #216 SMP PREEMPT Wed Jan 9 10:15:52 CST 2013
Android build:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/Play X/20130109.094407:eng/release-keys
Download:Â kasty-cube_u9gt5-based_hyundai_play_x900_20130109-41-rooted3.zip
For Cube U9GT5, should also work on compatible tablets: Chuwi V99, Visture V4HD, Yuandao N90 FHD, Hyundai Play X900
Use Rockchip Batch Tool version 1.5 to flash the firmware, use Restore button.
Please report any problem with this firmware. There is some extra cleaning to do with Chinese apps and homescreen, I'll make a new update soon.
mcschweg, algarroba, dmnokia, lakebear, theleftykid, Hoppa, Frontier, alexokanenas If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I got rid of the last unnecessary apps.
New firmware uploaded and download link updated in post #1.
teacher, karmantyu, pustel If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Which application have you tried and doesn't work ?
What does root checker says ?
2012/12/01
Root checker says it s rooted. But there's no su in the apps.
I tried ESfile explorer to edit the build.prop, i went in the settings to get root mode, but it was not working.
I edited build.prop but i could not save.
In the play store i could not get play books, or play music, nor facebook for exemple.Â
2012/12/02
lakebear said
Root checker says it s rooted. But there's no su in the apps.I tried ESfile explorer to edit the build.prop, i went in the settings to get root mode, but it was not working.
How about installing SuperSU or Superuser from Market? It is that simple.
Execute it, actualize binaries and you're good.
It definitely is prepared for root, but (as always) you have to have the apps installed and execute them for once.
2012/11/30
Hello I tried to install this firmware in to my u9gtv, it has now the original firmware from factory, but I can't do it, the Rockchip batch tool shows "This operation didn't do, because of not supporting" I dont know if I do it correctly, I'm not an expert. I have link the update folder in FW Path and then press the restore button, the tablet on and connect with the usb cable.
Did you put the tablet in flashing mode?
Do you see a green square on rhe rockchip tools when the tablet is connected ?
2012/12/02
cuu2 said
Hello I tried to install this firmware in to my u9gtv, it has now the original firmware from factory, but I can't do it, the Rockchip batch tool shows "This operation didn't do, because of not supporting" I dont know if I do it correctly, I'm not an expert. I have link the update folder in FW Path and then press the restore button, the tablet on and connect with the usb cable.Thanks
This is an easy one: "Restore" is not the right choice. Press "Update" and you're good.
68 Guest(s)
Devices in use: Desktop (60), Phone (8)
