2013/02/09
Hi to all of you
J've just acquired a cube U9GTV and like most of you, i have these memory issues, and leaks.
I would like to rrot the tablet with the lasted firmware but i cannot strt the flashing mode, i ve tried many time starting it by pushing the volume+ button, alone, or with the turn on button, but it just doens't work
i have activated the debug fonction, or not, but still the same.
can anyone tell me how i could do?
thanks
fred
2012/12/02
Everyone can tell you that, because it is the first thing you learn about the new tab:
hold vol+
(optional: also press power button in addition)
PLUG IN YOUR CHARGER into the tablet charger hole <----- this is the trick
watch RK Android Tool: "found device" will appear.
You are now ready to flash.
2013/03/01
I'm so sorry if this is repeated.. but I've been looking around for more than two hours.. and now, i have to ask.
I've been using the method described on: http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
but, when i go to my dispositive manager, the only 'other device' i see, is named N90 {not unknown dispositive}, and I try to install the drivers, as specified on the link.. (steps A to I) but it keeps saying that there is no controller/driver available for that dispositive. And therefore, no device is detected on the Rockchip batch tool... 🙁
:S:S i'm so confused right now..
anyone can help? thank you very much!
2013/03/01
thanks for the point, but as i said, i had been around here for two hours.. believe me, i would not have writen if i hadn't tried everything.. :SS
the thing is.. that after puting my u9gtV in flashing mode (+volume + charger = black screen with android robot laying on the floor with body opened).. y connect the usb, and my PC just recognizes "N90", and when i try to install the drivers.. it says it is not possible.. so i don't know what else i'm doing wrong.. :S:S
anyone any idea? thanks again! D
2012/12/02
That is an easy one: You are not in flashing mode, but switching to cwm recovery without having cwm installed. You should have tried the optional alternative and add pressing the power button.
Again: hold vol+, hold power, plug in charger cable, watch pc screen and rk android tool until it says found rk devicen.
2013/03/04
First of all thanks to the cooks, this is the first rom that has allowed me to work smoothly in HD, great work guys!
This morning I had a strange issue with this rom, with 75% battery it wasn't possible to wake it up so i had to do a hard reboot, after that the touch screen became extremely inaccurate, to a point in which tapping on the drawer triggered the search by voice, or tapping the home icon opened the notification area.
Am I the only one with this issue?
cheers, and keep on the good work
79 Guest(s)
2 Guest(s)
Devices in use: Desktop (63), Phone (13), Tablet (3)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
