Cube Chinese tablet manufacturer keeps improving their Android tablets, their latest Cube U9GT5 is equipped with a 2048x1536 pixels, 9.7" IPS screen. This high definition display gives a pixel density of 264 pixels per inch (ppi), just the same as Apple 3rd generation iPAD.
Cube U9GT5 specifications
CPU: Rockchip Dual-Core Cortex A9 RK3066 CPU running at 1.6GHz
GPU: Quad-Core Mali400 GPU
RAM: 1 Gb
Storage: 8 or 16 Gb
Bluetooth, WIFI
Camera with flash
Price and availability currently unknown.
Cube U9GT5 benchmarks video:
http://www.youtube.com/watch?v=tlwhkZG8X1E&feature=player_embedded
Via phonandroid.com
2012/10/22
globula_neagra said
can you share specs, bechmark results ?
For the bechmark results, that is almost same as what the supplier said. I can screen capture if you guys need
I only got U9GT5 three days before, no big issue until now. The following is only my personal feeling.
1. For WIFI speed, a bit better than my another P6200. Open web page also faster than P6200.
2. playing 1080p video without problem at all.
3. the touch screen a bit unstable, it shoule be the RK3066 Android Kernal bugs. I using stock ROM U9FT5 V1.0 now, hope they will fix it.
4. Because the screen resolution compatibility issue, only a few apps inside the google play store you can found :p
5. The Adb Interface Driver only work for data transfer, cannot use ADB Debuging. Hope they will fix it too.
6. btw, no battery temperature sensor, no hardware GPS, no hardware compass
7. camera is work fine in Skype.
76 Guest(s)
Devices in use: Desktop (63), Phone (12), Tablet (1)
Mikewood
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
