2012/11/02
Here it is the first oficial firmware for CUBE U9GT5 Quad Core RK3188 (THIS IS NOT FOR RK3066 - case sensitive).
Hope some good soul around here can have the time to perform a custom rom from this one.
MEGA: https://mega.co.nz/#!XEc2UJ6J!QfxVMUZGqFaCwzHHF8v8OhPqogR-CtcfjI9dHT58LsA
GDrive: https://docs.google.com/file/d/0B4rhoa67mZl2TFMxUWI2a01jU00/edit?usp=sharing
4shared: http://www.4shared.com/zip/dF2maPoC/...Quad_Core.html
Now if you need to ROOT this tablet, you can do it using two ways:
1 - using Zhuodashi (i used this one - the same way like the previous rk3066)
or
2 - (I did not tested this method, but they said its working - use it at your own risk)
https://docs.google.com/file/d/0B4rhoa67mZl2bmdjdTFnZ21KX1k/edit?usp=sharing
http://www.4shared.com/zip/E36qqFba/RK3188.html
Enjoy it
I'll download it from the original place (51cube.net) and see what I can do.
mml78 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Probably not, it's either a bad tablet PCB/case design or a WIFI firmware issue.
I'm moving this topic to the new U9GT5 (RK3188 model) forum section.
You'll find our custom here:
2012/11/02
grastogi78 said
hi,just ordered mine, what are your feelings on this so far. Any feedbacks on the performance etc.Â
Any one been able to create any roms for this? I wI'll probably try my hand as a noob to cook a rom For this will share if it works out.Â
gaurav
Yes, we have two cooked roms so far, one from 900supersport y one from Arctablet. Thanks to them.
2013/01/10
I've been tweaking my Cube because it's so slow and find that 2 options have a visible difference.
1. Force GPU Rendering - enable this in Developer options
2. Don't allow CPU to be in energy save mode.
I'm using ROM Toolbox Lite: go to Performance - CPU Control - choose PERFORMANCE as CPU Governor and DEADLINE or NOOP for IO Scheduler. This will eat your battery quicker, but your tablet will be faster (until we get proper firmware).
If you want to keep balance between battery and speed, choose INTERACTIVE governor but set minimal CPU frequency to 816 or 1008MHz by lower slider.
Now I can use my tablet normally. I can type SwiftKey etc (lag was too big to use this keyboard before these tweaks).
The following users say thank you to Davka for this useful post:
admin, ptimaxThanks for the tipcs Davka, I'll try that on other Android tablets as well.
Have you made any benchmarks regarding the battery life after changing the settings in Rom Toolbox Lite ?
2012/12/22
Thanks for the info Davka!
I tried the options. Will see if it helps. Although from the looks of it not much of help.
By the way I'm running a GlassROM developed by dark from freaktab.com. Seems the best available. For now I've underclocked my CPU to 816Mhz. I think this suffices my needs. I will run it at max when and if we get a ROM which will have better performance.
Gaurav
Currently Online: manumerayo
79 Guest(s)
Devices in use: Desktop (59), Phone (20), Tablet (1)
kuzin
Dag58
montolla
portvein
POELE
hststs44
