2013/01/10
New firmware Android 4.2.2 based on new SDK 2.0 for N90FHDRK (24.06.2013) - Cube U9GT5 100% compatible !! I really recommend this ROM
Features:
- A LOT FASTER, SMOOTHER GUI (new SDK 2.0 makes a real difference)
- more stable WiFi
- HD/SD mode switching (SD = 1600x1200)
Download:
http://pan.baidu.com/share/link?shareid=1196468481&uk=892608058
Clean version (no chinese apps, root)
http://hotfile.com/dl/231042416/076e5b7/Clean_Root_N90FHDRK-4.2-20130624.rar.html
The following users say thank you to Davka for this useful post:
jvolzer
2013/06/28
Features:
- more stable WiFi
Download:
I downloaded the clean version and it is really smooth. its the best firmware that I have used. The only thing is that the UI is the same UI that has been used in honeycomb through jellybean 4.1. Do you know if there is a way to get the normal android 4.2 UI?
2013/07/15
Hi all,
i own a Visture V97HD and found a link with firmwares to download (works also with N90fhdrk, u9gt5, x900, pad9719qr, etc...). The last online was uploaded on 10/29/2013, and is dated 10/10/2013.
So this is a visture one, not online yet on visture's website.
Been installed since last night with HD display and so far, battery drain is excellent, way better than with the dragon touch firmware. Everything seems fine, quick, and stable. I just scored an average of 5800 on quadrant and 18290 on antutu's, so it's quite the same. Epic Citadel gives me a
RKBatchTool is necessary to install firmware image.
I first did restore and let the tablet reboot till the end. Then I did once again but using upgrade.
Here's the link for who wants to try : http://pan.baidu.com/share/home?uk=571188649#category/type=0
Language is Russian on boot, and some apps are added than latest official like
I used ZhuoDaShi-2.2.0 to root the tablet , downloaded and installed uni-init v1.0.apk to enable init.d and then installed operation killjoy 100213 RC7 through recovery.
Just to inform you of my findings.
2013/11/21
Davka said
Simple ROOT script, works on my Cube U9GT5 and U20GT tablets:http://www.4shared.com/zip/7Bhsv6zX/41_ADB_Root.html
Just set to USB debugging mode in Developer options, plug in USB cable, install Android/Rockchip drivers (you can find them in official ROM package) and run root.bat from my zip archive. Then go to Google Play store and instal SU or SUperuser etc. and it's done
Much better option than dirty ZhuoDashi app.
Hello.
Does this action allow the root U9GT5 RK3188?
It should be done on the PC?
Cordially.
Currently Online: kkn
77 Guest(s)
Devices in use: Desktop (71), Phone (7)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
