2012/12/10
I saw a post for fix here -> http://www.slatedroid.com/topic/50354-gameloft-game-fix-for-license-check-or-loop/
I also have same problem of license check loop. The author says "This fix is for deodexed framework".
I am using v1.03 ROOTED, downloaded from this site. Is this rom deodexed? Will this fix work on my stock ROM/device?
Can you give me a short explanation about what is odex and deodex and where ".odex" files are stored?
... (I have also applied the V6 supercharger tweak to services.jar file and it is working.)
The odex file is storred in the same place as the app itself /system/app/
Eg:
Browser.apk
Browser.odex
To have only one file, respectively the apk, you need to de-odex the above 2.
I can not confirm if the firmware is deodexed.
Ashish
2012/11/22
Who want fix? http://yadi.sk/d/aQoi5uKf3Tx7e
Replace framework.jar from /system/framework/ and set premision rw-r--r--
Work great for me! Now i can play Asphalt7, MC4, Gangstar vegas
Tested on 1.0.3
47 Guest(s)
Devices in use: Desktop (41), Phone (6)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
