Firmware from Scopad Hercules for u9gt4?
ser63
Russia
2013/02/22 - 21:37
Hello. Thailand have OEM version cube u9gt4 and it have soo many customs roms! You can find it there http://www.thaiscopad.com/thread-755-1-1.html, on u9gt4 working with bugs (camera not working, memory mounting problems) :( Who can optimize cyanogen mod 10 from scopad hercules for u9gt4? It will be great! There download link for CM10 http://yadi.sk/d/z2fkj6pC2jlpZ
How to install?
Enter CWM Recovery . Wipe Data / Factory Reset. Wipe cache Partition. Install Zip from sdcard -> choose Zip from sdcard -> CM10-20,130,119th-DSciModForSP0718.zip -> Yes. Reboot. system now. reach this stage will not boot, press and hold the Power button to extinguish the file is in use by a 2 RKAndroidTool.exe open up and select the images. I then press the Flash ROM . wait until completion. Then disconnect the USB cable and wait for the Boot Login (if you screen Android supine press Power + Volumn Up and then release the button Volumn Up first, followed by the Power button, then select reboot system now).
The following users say thank you to ser63 for this useful post:
Ashish
mosasha
Forum Posts: 16
Thanks Received: 4
2013/02/23 - 14:47
i installed it and everything works ok including the camera and the memory mounting
cool rom btw thnx for sharing
ser63
Russia
2013/02/24 - 14:04
How did you do that? What rom you using before?
mosasha
Forum Posts: 16
Thanks Received: 4
2013/02/24 - 22:45
i was using a rom also from scopad u can download it from  http://www.slatedroid.com/topic/43489-rom-cube-u9gt4-first-flashable-zip-via-cwm-by-wasan007/ but after using the tab for a while with cm10 rom i noticed a slow graphics performance and battery indicator  is insanely inaccurate  too bad there is this bugs cus the rom is soo cool i hope some one can compile it to the u9gt4
Ashish
Forum Posts: 23
2013/03/22 - 15:20
Thank you, I will see if it works on my tab... :thumbsup:
Currently Online: VMILCINOV
62 Guest(s)
Devices in use: Desktop (58), Phone (5)
nikitamaan
VMILCINOV
