2012/12/23
[X-Post from 1.0.2 topic]
Hey guys, I'm having a real problem getting the drivers installed for this device.
I'm running Win7 x64. So far I can make it to a prompt where I can update driver software for "unknown device" from device manager. However, when I point Windows to the driver folder it gives me this error:
The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64-based systems.
This is when trying to use any of the drivers from Rockchip Batch Tool 1.5, and 1.4; and also RK Android Tool 1.29, and RK Device Manage 1.3. Every single time, the driver won't appear usable.
I even encounter the same problem on my old Windows XP (x86) box: absolutely no drivers work for this device there either. Of course I am selecting the proper driver folders (x64 for my Win7 machine, and x86 for my XP machine).
The only thing I can think of that might be causing the problem is that my Win7 machine is an Intel chipset and the Rockchip x64 drivers are in a folder called "amd64"… but my XP machine is an AMD, so I don't know why it doesn't work there either.
This is all messed up. I thought that after seeing some people on page2 struggle with the driver but ultimately work out the problems, I'd be able to do the same; and so I bought the device, but now I don't know what to do to solve this driver issue. I've been at it for hours already. Please help, someone.
2012/12/10
@Te3k
Have you used the LATEST update 1.03? This update comes in a ZIP where folder structure is "x64win7". You have said that you have "amd64" folder???
2012/12/23
Oh, that might be the problem.Â
The link in the OP includes only a zip archive with the file "update.img" in it. There are no drivers and I've never seen an "x64win7" folder before.
Would you please upload the driver files for me? It would be a real help.
EDIT:
Okay, so it seems as though there are some different drivers included in the stock (non-rooted) 2012-11-30 build of the firmware. These installed! Now my devices is detected as an RK30 device in Device Manager.
But neither Rockchip Batch Tool or RK Android Tool detect a device....
2012/11/24
Blur said
Cant play flash videos with this uptade, any sugestions?Â
I encountered the same problem, got around it with Root Uninstaller, uninstalled flash, boot and reinstall flash from xda-dev source flas .apk
Thx, i did what you say and i have now blue little lego box instead if video but still no playing
79 Guest(s)
Devices in use: Desktop (63), Phone (14), Tablet (2)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
