thanks for the tip, I'll take care of it as soon as I can download the file. Maybe you know of a mirror ?
Sounds good, would save me some time
2012/11/13
http://www.4shared.com/get/ZkqOmYG1/103_U9GT4.html
There ya go sorry it took so long
The cleaned & rooted 1.03 firmware is posted at:
2012/12/23
Hey guys, I'm having a real problem getting the drivers installed for this device.
I'm running Win7 x64. So far I can make it to a prompt where I can update driver software for "unknown device" from device manager. However, when I point Windows to the driver folder it gives me this error:
The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64-based systems.
This is when trying to use any of the drivers from Rockchip Batch Tool 1.5, and 1.4; and also RK Android Tool 1.29, and RK Device Manage 1.3. Every single time, the driver won't appear usable.
I even encounter the same problem on my old Windows XP (x86) box: absolutely no drivers work for this device there either. Of course I am selecting the proper driver folders (x64 for my Win7 machine, and x86 for my XP machine).
The only thing I can think of that might be causing the problem is that my Win7 machine is an Intel chipset and the Rockchip x64 drivers are in a folder called "amd64"... but my XP machine is an AMD, so I don't know why it doesn't work there either.
This is all messed up. I thought that after seeing some people on page2 struggle with the driver but ultimately work out the problems, I'd be able to do the same; and so I bought the device, but now I don't know what to do to solve this driver issue. I've been at it for hours already. Please help, someone.
2013/01/01
How to say that...You are just...AWESOME!
it s rooted! Thank you very much!
I still encounter some issue with the wifi module.
Just released: Cube U9GT4 official firmware version 1.02 U9GT4_V1.02_20121110.zip (2012/11/10)ÂÂ
Android build:Â rk30sdk-user 4.0.4 IMM76D eng.wbx.20120615.112351 test-keys
Linux Kernel:Â Linux version 3.0.8+ (root@yf-server) (gcc version 4.4.3 (GCC) ) #348 SMP PREEMPT Thu Nov 1 10:21:54 CST 2012
Here is a custom rooted firmware version of the Android 4.1 Jelly Bean based on official Cube version 1.02
Features:
- root with SuperSU 0.96 (free version)
- writable /system partition
Rooted custom firmware for the CUBE U9GT4: kasty-cube_u9gt4-41-102-rooted.zip
Using Rockchip Batch Tool version 1.5 to flash the firmware.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Cube U9GT4 to test it.
2012/11/10
Hi! There is alot of info already in these threads about flashing. First you need to download a firmware that you would like to install on the tablet. Then you use the rockchip tool inside windows to flash the tablet.
It's basically like this:
Turn off the tablet
Press volume+ and power for 3 seconds
Plug in usb to computer
Windows will ask for drivers and you have it in rockchip tool directory
Open rockchip tool and choose the firmware
Flash
78 Guest(s)
Devices in use: Desktop (67), Phone (10), Tablet (1)
antoniors021
wemiy54158
sidor
houssmen
qarolus
dav512
