2012/11/22
hello guys, first thanks for the firmware.
Bough a couple of these units for christmas gift for my kids.
I had some scare trying to flash the firmware on the second table, kind of half bricked it but in the end was able to salvage it.
Does anyone knows how to change the Id for the device so the app store thinks its another kind of device.
My yuandao n101 is identified as a GT9100 (included in the CFW I use) and I can play nearly everything on it. Its the same chipset so I guess it should work for these units too. I would like to be able to DL rayman, my kids love that game and it works great on the n101. Most of the apps are working already including gameloft games but I'd like to have the same access to the store as my N101. Can I modify that myself as they are now rooted.
About the tablets themselves, they are great for the price, I hope they last a couple of years. Nice design, good looking screen and very fluid with jellybean.
8Gb should be enough for the kids I won't download the space hogger of gameloft, kids are just 8 and 10.
porkepik said
Well I did find a way to change my tablet ID to make it look like my N101 (GT-P1000) but it stil does not want to download Rayman, granny smith and the western game by gameloft...ah well still not that bad.If anyone has an idea...feel free to write it.
thx
I'll check on the Cube U30GT-MINI and will let you know.
2012/11/13
i found this just translate download and change to english much better rom
http://www.51cube.com/bbs/forum.php?mod=viewthread&tid=52570&highlight=U9gt4
2012/11/13
also try this one Just have to flash and change language to english
2012/11/22
ok was able to download the unsupported app by changing the Android id name with an samsung S3 Id from sprint
ro.product.model=SPH-L710
ro.product.name=d2spr
ro.product.device=d2spr
Everything seems well .... except 1 game that resist my attempts ....granny smith loll.. guess I have to find a compatible ID
2012/11/22
2 ways :
easy one: download android name changer app on the play store, works well with the U9GT4
more dangerous one: with ES file explorer (another app on the store which is nearly 100% needed) in root mode, edit the build.prop file in the system folder and replace the lines I mentionned.
Caution make a copy of the build prop and don't tinker with anything else.
I used the two options just to check if android name changer was doing its job correctly. I would go with the name changer app.
Either option needs the tablet to be rooted
I tried some other fingerprints on my Cube U30GT-MINI, Granny Smith still shows incompatible with the device. I'll look for other ways.
porkepik: that may be a density issue.
Can you report your tablet screen density, either checking in the /system/build.prop or reading it from an application (for example Screen Resolution & Density in Google Play Store)
2012/11/19
Hello all, first of all thanks for the firmware.
Got some problems with adobe flash player. Though it seems to be installed all swf players or any other software using it tells me it is not installed or does not work propertly. Upgrade to newer version or uninstallation is not possible too. Error tells me the package has a conflicting signature.
Tried to flash it once more, thought that maybe something went wrong first time, but nothing have changed.
Does anybody have any solution for this problem?
2012/11/13
antifreeze said
Hello all, first of all thanks for the firmware.Got some problems with adobe flash player. Though it seems to be installed all swf players or any other software using it tells me it is not installed or does not work propertly. Upgrade to newer version or uninstallation is not possible too. Error tells me the package has a conflicting signature.
hello antifreeze
i did install flash player download flash player install a file explorer app for example (root access) and grant it the supersu permission delete the installed one you can find it in system\app and install the one you downloaded i did this and it worked
and you need to install a browser that support flash player such as mozilla
cheers
The following users say thank you to mosasha for this useful post:
antifreeze
2012/11/13
firmware download U9GT4 V1.03 (Battery Fix) Link~ http://www.51cube.com/ch/DownShow.asp?ID=109
75 Guest(s)
Devices in use: Desktop (68), Phone (7)
jacksonrid
usdown
ibob64
kawi
vetBro
