SMITHY
2012/11/24 - 09:48
Hi there it seems that my cube u9gt4's battery life is draining about 100 times quicker than when then screen is on just wandering if any body had a solution to my problem because otherwise it is a fantastic little device
Cheers
Tom
ver4rs
2012/11/27 - 16:12
Hi, I have the same problem, do not know how to fix it? Tablet me it was only when I got it in the charger when selecting from the charger turns off after a while.
Thank you.
koliny
2012/11/27 - 17:20
I have the same problem....what charger you have?...I thing it might be problem in the low cost china charger....I am going to buy quality 5V, 2A charger. I will let you know if it solve the problem
ver4rs
2012/11/27 - 17:28
Where are you from ? I am from Slovakia.
I bought it from China the banggood.com site.
SMITHY
2012/11/27 - 17:31
I am English and bought from deals prime seems like a fault with the tablet not the company its a brilliant little device though when it has battery do you agree
ver4rs
2012/11/27 - 17:39
Me it only when I have it in the charger when it disconnected from the charger so after a while off. I do not know as may be error.
ver4rs
2012/11/27 - 17:44
I have 5V, 1000mA.
koliny
2012/11/27 - 19:42
Aj na strankach výrobcu píšu, že potrebná je 2A nabíjačka. Terat som kúpil novú 2A nabíjačku. Tablet sa nabíja, počkám kým sa nabije a dám ti vedieť či to fungovalo....dvaja slovaci :D ...aká náhoda :D
Thanks Received: 264
2012/11/27 - 20:12
please write in english
what he said is:
Even the manufacturer's website writing that is necessary 2A charger. Tera, I bought a new charger 2A. Tablet is charging, wait until the charge and I'll let you know if it worked .... two Slovaks ... what a coincidence
ver4rs
2012/11/27 - 21:10
koliny
funguje to, nabija jak ma, vydrzi baterka ?
napis mi tvoj email aby naša komunikácia neviazla, písať môžeme aj tu naše postrehy, skusenosti, pomoc ale cez email, chat by to bolo rychlejsie.
ÄŚi?
SMITHY
2012/12/02 - 09:29
hi guys just wandering if any of you have managed to fix the problem the only problem i have know is the battery going down quickly
Thanks Received: 3170
2012/12/02 - 18:02
Maybe latest firmware helps fixing the problem:
http://www.arctablet.com/blog/forum/cube-u9gt4/cube-u9gt4-rooted-firmware-from-official-version-1-03-dated-20121130/
I can't confirm as I don't have a Cube U9GT4, but that may be worth trying.
koliny
2012/12/02 - 18:45
Did you try to replace the charger with quality 2A 5V? For me it fixed the problem and you should try to charge for several hours
SMITHY
2012/12/08 - 09:50
How long does your battery last now
Byron
2012/12/10 - 20:22
I had the same problem
changing charger doesn't help here.
I tried with :
- 2A genuine hp touchpad charger
- 2A genuine galaxy S3 charger
I notices that the battery percentage in charge only grows after about 2 hours after plugged to the charger
Battery drain : 1% every 3 seconds !!!
Maybe there is a problem with kernel battery stats...
I have the same problems with official 1.0.1 firmware and 1.0.3 rooted firmware...
Currently Online: fantom0308, MINIX2021
115 Guest(s)
Devices in use: Desktop (102), Phone (14), Tablet (1)
beelink
TheMentor
smalec
marek.test@gmail.com
MINIX2021
extendedtn
