this is the original vold
## Example of a standard sdcard mount for the emulator / Dream
# Mounts the first usable partition of the specified device
#dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9
dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb /devices/platform/usb20_otg/usb
## Example of a dual card setup
# dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
# dev_mount right_sdcard /sdcard2Â auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1
## Example of specifying a specific partition for mounts
# dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
Modified one
#dev_mount sdcard /mnt/external_sd auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
dev_mount sdcard /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
It this does not work, provide a mount value from adb shell mount
You need to flash you tablet i think with rockchip tools, but still, why did you not enabled usb debugging ?
as i said, i need the mount values
you need to install android sdk and all the other related stuff
then connect the tablet to the pc, enable usb debugging, install the drivers
use adb and issue the fallowing
adb shell
mount
and copy paste the value somewhere
try to use superoneclick, and see if installs it right
to check if the usb debugging drivers are corectly installed use
adb devices
then try to google some drivers for your tablet, uninstall the one that you have now, and install the new ones that you will find
95 Guest(s)
Devices in use: Desktop (84), Phone (11)
Ellocojoe
Tonysc17
olegator
Ur
beelink
TheMentor
