2012/11/22
hi folks,
here is the list of my issues:
1- auto shutdown when battery is coming under
2- browser is crashing when i try to use vocal search
3- some compatibility minor issue with flash content and web browser (chrome seems to be the best, ff the worst)
4- minor compatibility issues with few apk, but this may be due to me
as for now, except the battery issue, and the poor quality of the charger, this device rocks!!!
2012/11/22
coincoin said
hi folks,here is the list of my issues:
2- browser is crashing when i try to use vocal search *fixed with JB FW
I'm trying to tweak my build.prop, but i'm not sure which device build.prop shoul i take
Nexus 7 obviously, but if someone has a "how to" or a link, it would be nice
thanks
2012/12/15
Hi coincoin, how long does your Cube last before shutting down? Mine can shut down within 30 minutes at 60%. But when it came it would actually sustain 3-4 hours of demanding gameplay without shutting down.
I might have a faulty battery cell here but it's hard to say for sure.
Josef
Try to close all the working apps before you put your tablet in stand-by.
Go to settings/apps/running apps, and close everything from there.
See if you get any improvement.
2012/12/15
definetely an issue with that battery, or at least with the monitoring of the battery
sometimes you are consuming 10% in 3hours, sometimes in 10 minutes
sometimes it shutdown at 40% sometimes at 50%, you nerver know
Thanks,
just two short questions:
Does your tablet report battery temperature (mine does not)?
And what is the battery voltage when fully charged (mine's got 4V at 100%)?
2013/01/02
The battery issue is said to be fixed by this firmware : http://www.jmitech.fr/media/jmitech/JMITabT970_Firmware_26082012.rar
From what they say, you may fix it be recalibrating the battery (full charge then remove /data/system/batterystats.bin) several times.
The following users say thank you to Meex for this useful post:
worm321
2013/04/09
U9GT3S
1.04 rooted chiniese
- some times, being switched of, tablet screen became white. Look that it just wakes up, but does not show lock screen - just white screen.
I've read that this problem was discussed somewhere on chiniese forums. Do somebody know, was it solved in 1.05?
2012/11/22
The battery issue is said to be fixed by this firmware : http://www.jmitech.fr/media/jmitech/JMITabT970_Firmware_26082012.rar From what they say, you may fix it be recalibrating the battery (full charge then remove /data/system/batterystats.bin) several times.
Not in the good section, don't try that old firmware for old tablet only
87 Guest(s)
Devices in use: Desktop (77), Phone (10)
hans41
rickybk
soniya07
ironmangitar
