u9gt3 8inch flash mode
mik3000
2013/01/02 - 11:39
hello
how do i get the u9gt3 (8inch) in flash mode ?
thanks michael
Thanks Received: 268
2013/01/02 - 19:40
If you have the usb debugging drivers
you can use adb and get your tablet in flashing mode
adb reboot bootloader
mik3000
maxpower85
2013/01/18 - 00:39
I'm trying to do adb reboot bootloader, but I get device not found
Usb debugging is ON
but I seems to have problem with driver.. in device manager I see an error on u9gt3.. where I can find the good driver?
thanks!
2013/01/18 - 13:39
well, you can try to install the adb drivers with superoneclick
then check if you got them right by verifying with the command
adb devices
If you get a positive result here, then you can use
And the tablet will enter in the flashing mode requesting the rockchip drivers which you will find them in rockchip tools.
maxpower85
2013/01/18 - 14:38
It's working now.. but that was tricky..
needed to add hw device id in the driver file of ADB driver (from google sdk) :
C:/Users/<USERNAME>/AppData/Local/Android/android-sdk/extras/google/usb_driver/android_winusb.inf
%CompositeAdbInterface% = USB_Install, USB/VID_2207&PID_0010&MI_01
%SingleBootLoaderInterface% = USB_Install, USB/VID_2207&PID_300A
Install this driver for my "U9GT3" device
create a file c:/users/%username%/.android/adb_usb.ini and add 0x2207 value in this file.
then adb devices works!
then adb reboot bootloader too!
Install rockchip driver for the new device detected
then flash FW from rockchip!
The following users say thank you to maxpower85 for this useful post:
Meex
Meex
Forum Posts: 19
Thanks Received: 6
2013/01/24 - 23:34
Thanks a lot you are my savior ^_^
I bricked my U9GT3 by trying to DIY the firmware with the Wendal toolkit... obviously something went wrong !
(actually now I think that the download mode can be reached by turning on the tablet while pressing "vol+"... the charger has to be unplugged before, you can replug it once you're in download mode)
47 Guest(s)
Devices in use: Desktop (39), Phone (8)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
