2012/09/27
Actually, it's ready now U9GT3-S only !
Hi, thanks. It works. Only the model number is now U23GT-S. I will do some more tests.
2013/02/16
The same with me. Everything works fine now. I changed the name with Build Pro.Now its called U9GT3-S.
But maybe I am wrong, I think the original was running a litle bit smoother. Anyone an idea what was changed in the S-version? All Hardware progs show now a core clock of 1.4 ghz.
Maybe the admin will transport our messages into the download area for the S-version(1.04), it could be that this versions are little bit confusing for somebody.
My tablet is a Cube U9GT3-S
Which tablet do you have Hunkin ? Is it the U9GT3 or U9GT3-S ?
On Cube website the package dated from 2012/03/04 contains an "old" firmware V1.05 (20121213) for the U9GT3. The update for the U9GT3-S is newer (V1.04-20130227) but I'm not sure it works on regular U9GT3, not U9GT3-S.
2013/02/16
I have the U9GT3-S. This firmware seems to be newer. I installed the original and the problem with the modellnumber seems to be solved. Also there were no spopntaneous reboots. But curiously the version for the U9GT3 seems to be one day older then the last posted. Thanks in advance for your help!
2013/02/22
 I have the cube U9GT3 with the 1.05 rooted firmware from this site .I had the 1.03 rooted and it was smoother and had higher benchmark scores also .The 1.05 is a bit slower and it is visible when scrolling pages up and down .Every thing worked but the flash player.I had to uninstall it ( it is a system app and needs an app to uninstall it )and re-installed it and now it works fine .The wifi is the same with all versions i have tried but is is no way near as good as my son`s i-pad mini .The original firmware it came with was smooth but had a lot of Chinese apps and a very weird keyboard .
2013/04/03
I tried the rooted firmware, when the rockchip tool do the test, this fail and my cube can´t start, only show a black screen. The pc recognize the tablet. Can you help me?
I solved flashing a original previous rom and flashing again the rooted firmware.
Thanks, and sorry for my english.
2013/03/25
I flashed my cube u30gt3 with FW 1.05 and changed the build.prop so that it can access to all the application of google store.
But it is frozen with the start animation.
Here is the lines of conf modified build.prop :
ro.product.model=GT-I9100
ro.product.brand=samsung
ro.product.name=GT-I9100
ro.product.device=GT-I9100
ro.product.manufacturer=samsung
I did the same thing on my MK808 dongle. it works, I do not understand why ...
Have you any idea?
thx
2013/03/25
Hello ,
The cube was in official Cube version 1.02
I 've tested 3 rooted fw :
With "kasty-cube_u9gt3-404-103-rooted" and "kasty-cube_u9gt4-41-103-rooted" No possibility to activate WIFI on U9GT3
With Rom 1.05 , Problems batteries , system low , Synchronisation Google account KO , no possibilty to change the build.prop fot access to all the application of google store....
fw kasty-cube_u9gt3s-41-104-rooted is compatible with an u9gt3 or brick risk ?
Another Firmware is available and works ?
Thx
111 Guest(s)
Devices in use: Desktop (102), Phone (8), Tablet (1)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
