2013/01/23
Anyone else having trouble with WiFi dropping out? Â After the change to 1.05 it'll lose wifi when it goes to sleep, and I have to go into settings and turn wifi off and then on again, which makes it work perfectly again. I'm not sure if it's the original ROM or the custom one that's causing it, since the wifi was dodgy even out of the box. Â Other than that, the rooted firmware is still running awesome and nothing has crashed on me yet.
2013/02/03
I recently received my U9GT3 from PandaWill and it came with the 1.02 firmware.
Running Antutu it shows core clock of 1.6GHz and a final score over 12000.
Yesterday I flashed the 1.05(rooted) and the max clock goes to 1.4GHz(even with SetCPU) the final Antutu score drops to 9000.
There is any reason for this??????
Is this normal?
Can I do any thing to get a better performance?
Thankyou all!
I can't speak as an expert, but I noticed sometimes manufacturers make these kind of clock changes, either to save battery, prevent overheating or stability problems.
This is probably done at the kernel level, so it may be possible to rebuild a firmware mixing an older kernel with 1.6 GHz support and a newer "system" Android build.
Has anybody noticed a new U9GT3 firmware release from Cube ?
http://www.51cube.net/ch/DownShow.asp?ID=137
From the Chinese translation, it seems there are 2 versions, one for U9GT3 and another for the U9GT3S that cannot be swapped as the tablet's hardware may be different.
2013/02/16
Hello, today I received my Cube U9GT3 from China. Its the 8" model, and it seems a U9GT3-S.
Thats on the back:
Model: Cube U9GT3
U9GT3S16GBW13066321066F
Opening Adjustments and System the model is shown as U9GT3-S
Android-Version 4.1.1
Kernel 3.0.8+ eyes#0001@lzhp-System-Product-Name#379
Build
U9GT3-S
U9GT3-S_COF-GT911_V1.02_20130201
I cannot see any differences to the version without s.
OK, after testing a little bit, there are some strange things for me:
Android System Info shows a RK30 board, the cpu has only 1 core and 1,4 Ghz
Who knows a good hardwarecheck app?
In Antutu it reaches 11148 points.
I like to upgrade to the new 1.4 firmware, but I am not able to install the drivers.
Still having trouble with charging. Power supply gets warm, but display shows after one hour all the time 33%.
giulia.spider said
Hi, I got the U9GT3-S and I flashed the 1.05 rooted firmware. The display don't work and the tablet switch off after pulling out the usb cable. I will try to install the 1.04 standard mentioned above. Any plan about the 1.04 firmware + Root?
I should be able to root the U9GT3-S firmware in the next few days, I will post updates in the forum when ready.
Actually, it's ready now  U9GT3-S only !
Hunkin2012, giulia.spider If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/02/16
Ok, i found the way to install the drivers and update the firmware. Not so easy.
Most of the explanations are not good.
So for anybody having trouble wit code10 after installing the drivers by hand here could be maybe the solution
Install the drivers by hand choosing an rk30 device. Ignore all erros during install also code 10. On the tablet the USB debugging must be switched on
- disconnect tab from USB / PC
- switch the tab off
- plug it again to the pc and press Power on and volume + together
- the pc recognizes the tab as RK30 device, in this moment leave the buttons off and the screen appears all the time black from the tablet
- now you can update the firmware
No idea, I haven't made any change in the build.prop and I don't think there has been any mix in the firmware archives here.
Currently Online: iposad40
73 Guest(s)
Devices in use: Desktop (65), Phone (9)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
