help!!!!! how to root Cube U55GT quad core
nangiuhoa
Forum Posts: 21
2013/08/26 - 23:47
ok. I have just sent to you root file and driver file. you try to best!. ok ok
http://pan.baidu.com/share/link?shareid=454815&uk=2318828147 - root.exe
http://www.mediafire.com/download/4ai5yq02d3w4j5w/MT65xx_USB_Driver.zip. - driver
Trên điện thoại,Vào Setting > Aplication >Development
Check USB debugging
Connect với computer
find the way to folder MT65xx_USB_Driver. and set up , the same set up other hardware
nangiuhoa
Forum Posts: 21
2013/08/26 - 23:53
admin sa. I
As an alternative, I will post. C custom pre-r. :) ) ted firmware to test later this week, work almost done Wink
Tk admin  I hope a frimware is good and have  Cwm to back up
nangiuhoa
Forum Posts: 21
2013/08/27 - 03:20
globula_neagra said
Can you share a link, maybe someone else want to root this device also.
  1. Trên điện thoại,Vào Setting > Aplication >Development
  2. Check USB debugging
  3. Connect với computer
  4. find the way to folder MT65xx_USB_Driver. and set up , the same set up other hardware.
gino66
Thanks Received: 5
2013/09/02 - 01:20
hi,
firmware stock chinese : v1.02 released 2013.08.19 : http://www.51cube.net/ch/DownShow.asp?ID=178
or directly : http://pan.baidu.com/share/link?shareid=2547471089&uk=288410357
firmware stock english + tools (SP_Flash_Tool_v3.1316.0.150 + MTK drivers) : released 2013.08.20 : http://www.51cube.com/en/DownShow.asp?ID=189&pageview=down
or directly : http://pan.baidu.com/share/link?shareid=307088033&uk=288410357
Hope you made soon a custom firmware...
Thanks for your working
The following users say thank you to gino66 for this useful post:
nangiuhoa
107 Guest(s)
Devices in use: Desktop (104), Phone (3)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
