At first look this seems quite doable, as the system image is directly exposed in the firmware archive.
Still, there's a checksum in the package that would not compute corrected with a modified rooted system image, so I need to figure out first if this can be fixed...
nangiuhoa If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/03/10
At first look this seems quite doable, as the system image is directly exposed in the firmware archive.Still, there's a checksum in the package that would not compute corrected with a modified rooted system image, so I need to figure out first if this can be fixed...
thanks you so muck. and I hope you try  to  find how to root that chip... save and sound . hủra hura
it would much easier if you try this, and upload the results somewhere
http://www.arctablet.com/blog/forum/firmware-development/dumping-firmware-on-arnova-g2-arnova-g3-and-other-rockchip-based-tablets/
nangiuhoaGlobula,
The firmware for the U55GT is actually available here:Â
http://www.51cube.net/ch/DownShow.asp?ID=178
It's a phone, not Rockchip based, the system image is available in the firmware, but there's a file with checksum of the images. It's may be a bit risky to try flashing the phone with a modified system image with the checksum from the original one untouched.
2013/03/10
my chip is not RK .:(
2013/03/10
Globula,The firmware for the U55GT is actually available here:Â
thanks!. has this Frimware  root inside ????
2013/03/10
from up to now. I only use frimeware in http://www.arctablet.com because I alaway belive this site, so I am worry about other frimwares
Is more complicated on a MTK chipset, even if I provide you with a boot.img that allows you to root the tablet, you cannot flash it via fastboot.
Have a look here
http://forum.xda-developers.com/showthread.php?t=1982587
And here
https://play.google.com/store/apps/details?id=com.mobileuncle.toolbox&hl=en
Le: I just saw that the scatter file it is included in the firmware so in theory if you download the tool, you should be able to flash only the boot.img, then push it to the tablet.
nangiuhoaI found a way to update the checksum for the a modified (rooted) system image, I should be able to prepare a custom firmware in the coming days if you want to test it.
I can't be sure it will work as I don't have a U55GT device to test it.
2013/03/10
I found a way to update the checksum for the a modified (rooted) system image, I should be able to prepare a custom firmware in the coming days if you want to test it.I can't be sure it will work as I don't have a U55GT device to test it.
Hey. Tk everypeople!! After trying to find root.exe, i found it. It is chinese app. But its stong. I have already rooted my device. Hura hura
Can you share a link, maybe someone else want to root this device also.
As an alternative, I will post a custom pre-rooted firmware to test later this week, work almost doneÂ
Currently Online: runehansen76
68 Guest(s)
Devices in use: Desktop (56), Phone (12), Tablet (1)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
