[ ROM ] Cube U39GT Android 4.2.2 custom root firmware version 1.06 (2013/11/23)
kdish
61
2013/12/30 - 18:35
I can't seem to make the Rockchip Batch Tool detect the tablet. I have installed the Rockusb drivers and the tablet is detected by Windows 7 ( I get an icon in the taskbar for the Rockchip device)  while holding Volume+ and Power, but nothing happens in the RB Tool.
Please help, the Win8 wannabe launcher is making me sick.....
Thanks Received: 3169
62
2013/12/30 - 18:43
You can try the link below as an other option to install Rockchip drivers:
http://www.arctablet.com/blog/forum/firmware-development/rockchip-released-an-easy-driver-installer/
brogyi
63
2013/12/30 - 18:46
josepz said
How you did? I can´t see nothing better than 1280x720p in HDMI resolution options...
I had a rights problem with my local Solaris file server and I could not play any 1080p movie on the tablet. The HDMI resolution is same as yours. Sorry for that.
kdish
64
2013/12/30 - 18:54
You can try the link below as an other option to install Rockchip drivers: http://www.arctablet.com/blog/forum/firmware-development/rockchip-released-an-easy-driver-installer/
Thanks! I tried the package in the link but still the same behavior. Nothing happens in the RB Tool window.
Any other ideas?
brogyi
65
2013/12/30 - 18:58
If I get it right, the firmware on that page is for the U30GT C4, not the U39GT.
You're right but for me the chipset are exactly same. So it must work with this hardware too. I know there are differences but not too much. I hope you can made a kitkat version  in short time.
66
2013/12/31 - 00:36
SaberCZ said
Thanks for reply :)
I've tried on 1.06 image this. I copy 1.06 to the SD card and than tablet asked me, if I want to update it. I tried it only from 1.06 and everything was same. Can it help if I will try this? How the other members installed this ROM? How is it possible, that on my tablet this isn't working and on the other tablet it works?
Copying update.img file to the tablet internal storage or sdcard will probably cause problems,  the only proper way to install the firmware is flashing with Rockchip Batch Tool version 1.7 using Restore button.
josepz
67
2013/12/31 - 01:20
You can try the link below as an other option to install Rockchip drivers: http://www.arctablet.com/blog/forum/firmware-development/rockchip-released-an-easy-driver-installer/     Thanks! I tried the package in the link but still the same behavior. Nothing happens in the RB Tool window. Any other ideas?
I had the same problem, it seems that the tablet turns off quickly.
What I did was open RB tool, then connect the usb, and then press volume+ and power on, in this order...
Try...
kdish
68
2013/12/31 - 11:53
Try...
I tried, still nothing happening in the RB Tool window.....
I will try on another computer next.
kdish
69
2013/12/31 - 12:13
I managed to flash my tablet using another computer.
Thanks a lot for the help!
SaberCZ
70
2013/12/31 - 13:51
SaberCZ said
Thanks for reply :)
Hi admin,
Thank you for reply, but look at this post, which was before upper one.
SaberCZ said
For me doesn't work. After installation (by restore button in RB Tool). Everything goes well, but screen is flashing randomly. Flashing means, that on the screen I can see everything and for a half second probably I can see only black screen. It happens maybe 3 times every second. When I install the old ROM (http://www.arctablet.com/blog/forum/cube-u39gt/cube-u39gt-android-4-2-2-custom-root-firmware-version-1-04-test-version-20130723/#p30189) everything is OK.
Can anybody help me with this problem?
EDIT: I've tried to upgrade it in RB Tool from the previous version, that I've mentioned upper. Firstly I was fascinated, because it isn't flashing, but a few minutes late it comes again :/. So I've installed back previous version.
71
2014/01/02 - 22:35
I don't have a Cube U39GT so I can't check the firmware, but it looks like there is some positive feedback from other users using the 1.06 firmware from post #1, not sure what is happening in your case.
josepz
72
2014/01/03 - 02:01
Solved, the problem with the games was my fault, no firmware bug. I forget to create the play store account before opening the games. So, they don´t worked.
raph07_08
73
2014/01/03 - 17:56
great rom but 2 questions:
- after installing the rom the reboot seems longer (about 40 seconds vs 30 seconds with the original rom). Is it the same for you ?
- when the tablet arrives to logging screen, if there is no action during 1 or 2 seconds , the tablet goes to sleeping mode ... it is quite annoying. Anyone has this ? and how to avoid this ?
pepino10
74
2014/01/03 - 22:16
Start system is very long, more than a minute. Especially since disappeared Chinese applications!
n3kr0
75
2014/01/06 - 16:44
Hi there, i have the same problem that i had the first time i bought the tablet, the charge did not worked the first time i put the tablet charging, i tried to do what i read somewhere - put the tablet to rest a few days then try again. It worked. After a few weeks with no problem i flashed the tablet to 1.06 and when tried to charge it again when it came down to 10% the charger did nothing, i turned it off, but nothing at all.
does anyone have any tips?
Currently Online: Băiatul bestie, braydendevin313
107 Guest(s)
Devices in use: Desktop (99), Phone (9), Tablet (1)
braydendevin313
Băiatul bestie
mackoy
viktorial
mad15
ahmet05
