[ ROM ] Cube U39GT Android 4.2.2 custom root firmware version 1.06 (2013/11/23)
Tezray
Forum Posts: 18
46
2013/12/28 - 16:49
I have that thumb nail issue also. It does seem very stable. is there a way that the speaker volume could be slightly increased having only one speaker and it is very quiet. Otherwise I think my wifi has settled down quite well now. Thanks.
brogyi
47
2013/12/28 - 19:05
c3nk0 said
Remain real problems the long charging time ...
How long does it take the charging? The real problem is the charger switch off itself because of overheating.
I've changed the charger and testing now. Every 5V/2A charger is a piece of shit. Sorry my english.
I've tried 2 of them. Not worked properly all what I've tried.
Please look for a 5V/3A charger. It will be better. The tablet is not a heavy load but the charger very weak.
retrorat1
48
2013/12/29 - 12:10
Thanks guys but nothing seems to work. Even with the tab off and pressing the volume button and power the connect sound comes but does not actually connect . Tried the reset button next to the volume and now there is a kind of clicking noise when it is powering up about 4 or 5 clicks . Still trying. Don't want to send it back to China.
JugeHuge
Forum Posts: 26
49
2013/12/29 - 12:25
My ten cents on this.
1. run Rockchip Batch Tool 1.7 as Administrator, open flashable image ready.
2. connect device straight on usb. Be sure that it's direct usb and not through hub.
3. Power on tablet while also pressing volume + button
4. install RockusbDriver, then device should appear with a green icon in Rockchip Batch Tool
If driver is installed but still no green icon. You are then probably connected through usb hub.
5. either hit Restore to wipe and install, or Upgrade
Atleast for me i had to keep volume + and power button pressed as long that i got restore on going.
retrorat1
50
2013/12/29 - 13:00
Got it to upgrade . Thanks JugeHuge . Tried it your way but it wouldn't install the drivers. Restored windows to 3 days ago and tried again and it installed the drivers and I followed JugeHuge post and it worked. Thanks a lot guys.
retrorat1
51
2013/12/29 - 15:14
@c3nko : try a 5v/3A charger it works perfectly and has a quicker charging time.
The following users say thank you to retrorat1 for this useful post:
c3nk0
SaberCZ
52
2013/12/29 - 15:45
For me doesn't work. After installation (by restore button in RB Tool). Everything goes well, but screen is flashing randomly. Flashing means, that on the screen I can see everything and for a half second probably I can see only black screen. It happens maybe 3 times every second. When I install the old ROM (http://www.arctablet.com/blog/forum/cube-u39gt/cube-u39gt-android-4-2-2-custom-root-firmware-version-1-04-test-version-20130723/#p30189) everything is OK.
Can anybody help me with this problem?
EDIT: I've tried to upgrade it in RB Tool from the previous version, that I've mentioned upper. Firstly I was fascinated, because it isn't flashing, but a few minutes late it comes again :/. So I've installed back previous version.
JugeHuge
Forum Posts: 26
53
2013/12/29 - 17:18
Have you tried with 1.04 image on tablet that copy 1.06 update.img to the SD card with PC and then put that SD card to the tablet. It should find it and then ask for update.
SaberCZ
54
2013/12/29 - 17:48
Thanks for reply :)
I've tried on 1.06 image this. I copy 1.06 to the SD card and than tablet asked me, if I want to update it. I tried it only from 1.06 and everything was same. Can it help if I will try this? How the other members installed this ROM? How is it possible, that on my tablet this isn't working and on the other tablet it works?
pepino10
55
2013/12/29 - 22:33
Hi, thanks a lot for new and mostly clean firmware 1.06 is super!! Laugh
c3nk0
56
2013/12/30 - 11:02
Thanks for the tip! Laugh
brogyi
57
2013/12/30 - 11:47
What is your opinion or experience about this? http://bbs.51cube.com/thread-85623-1-1.html
If you have any related information pls share with us.
plebface
58
2013/12/30 - 17:42
What is your opinion or experience about this? http://bbs.51cube.com/thread-85623-1-1.html If you have any related information pls share with us.
KITKAT!!!! Can someone translate plz!
Thanks Received: 3169
59
2013/12/30 - 18:13
You can use Google Translate to get an idea of the page meaning:
http://translate.google.fr/translate?sl=zh-CN&tl=en&u=http%3A%2F%2Fbbs.51cube.com%2Fthread-85623-1-1.html
If I get it right, the firmware on that page is for the U30GT C4, not the U39GT.
josepz
60
2013/12/30 - 18:23
brogyi said
I had more time to check the resolution and it's working with 1080p. :) Thanks again the firmware.
How you did? I can´t see nothing better than 1280x720p in HDMI resolution options...
86 Guest(s)
Devices in use: Desktop (81), Phone (5)
Băiatul bestie
mackoy
viktorial
mad15
ahmet05
aymen57
