2013/07/22
I tired the firmware from xda (both stock 4.2.2 with multi windows and CM 10.1 alpha3) and no luck.
Flashing done according to procedure but the tablet boot loops :/
I extracted kernel.img from admin ROM but it seems it maches the one from Oma so it is not a problem of kernel
Back to admin last custom firmware with huge battery drain.
2013/09/23
Hey Guys,
Has any one tested out the Vondroid rom? see below....
http://vondroid.com/resources/cube-u35gt2-20130710.267/
2013/07/25
Hi everybody!
I've found the new firmware for our tablet here:
The default language is Russian, сhinese apps removed.
2013/07/12
I've had no success any of the XDA firmwares. They either resulted in boot-loops or even with successful boot, the screen doesn't respond to touch.
Would very much appreciate if someone could be kind enough to test the 1.06 and post the results.
I've got too many apps installed already for my little girl and she won't appreciate me messing around.
Thanks for posting the links.
2013/07/22
soner4arc said
Hi everybody!I've found the new firmware for our tablet here:
No changelog, it seems.
2013/08/19
Oma posted another rom to test: http://forum.xda-developers.com/showpost.php?p=45821855&postcount=642
Could someone test?
2013/07/23
Yes, I have installed this rom yesterday. It has been installed correctly, without any issues about booting loop or something else.
Ethernet dongle and usb hub are working well, 4xMSAA is present (for some games like GoF2), Antutu shows 18949 points.
Still testing but It seems like a very nice 4.2.2 custom Firmware.
P.S. I have also downloaded 4.4 and 5.1 version of rom (SDK 2.0 / SDK 2.0 MultiWindow) with OMA's version of Cube Kernel image, but don't tested it.
Could someone try to test 4.4 / 5.1 ?
WBR, Alex.
2013/07/12
Oma posted another rom to test: http://forum.xda-developers.com/showpost.php?p=45821855&postcount=642 Could someone test?
Cube U35GT2 by Oma rocks – JB 4.2.2 Edition v3.4
- CWM 6.0.3.1 recovery
- system ext4
- latest kernel
- internal Storage 4,0 GB
- device spoofed as Nexus 7
- TabletUI & Multi-User
- battery percentage mod
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial)
- latest hosts, su, su-binary, busybox
- FX Sound
- Reboot Menue, CPU Tweaker, Pimp my Rom
- Dateimanager HD (Root)
I've installed above but not fully tested it. Battery on standby lasts 6 hours with wi-fi on and just surfing the net (no videos).
The following users say thank you to Acel337 for this useful post:
aleitaly, drm3
2013/07/31
to Acel337
I installed this new firmware. Boot is fine and everything looks ok...just Google Search sometime stop.
Still testing just installed.. I will let you know details in the next few days
Thank you to everybody!
2013/07/31
Battery is really a problem... goes down very very fast. if you use the pad my battery last for less then 1 hour!!
– CWM 6.0.3.1 recovery
– system ext4
– latest kernel
– internal Storage 4,0 GB
– device spoofed as Nexus 7
– TabletUI & Multi-User
– battery percentage mod
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– kernel modules (cifs, tun, lan, serial)
– FX Sound
– Reboot Menue, CPU Tweaker, Pimp my Rom
– Dateimanager HD (Root)
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
jacksonrid
usdown
ibob64
kawi
vetBro
